Black Series Brakes
Of course because the V6 are much short then the V8 and so your the clips point are different.
No setting but you can change the brake line to a smaller size and it will reduce the pressure.
The smaller rotors will work in term of grip but then you might run into 2 problems. First, the 2 brake pads might touching one another when it wear down to about 90%. But the main concern is, the edge of the rotor will wear out and weaken the rotors structure and can cause the rotor to warp/crack very easy. If you look at every rotors wear, there's about 2mm of the rotors eadge that the brake pad does not touch.
When I get everything I will be doing a series of dyno runs after each mod to track actual gains. I've already done quite a few of these type projects before and I know the gains are all going to be minimal but I want to record raw data none the less. The airbox will be the first to go on and test because it can also be easily removed and replaced with the original airbox.
To reduce pressure you need to increase a line size. To very simply explain this take your garden hose, turn the water on and place your thumb over half of the hose end - the water comes out of the hose at a higher pressure. Take your thumb off and the pressure decreases.
The safe, easy, effective and proper way to make the adjustment is to use a proportioning valve, anyone or any shop who have done custom/track car brake set ups will know what this is.
*edit* Here is some good reading on the subject;
http://www.chevyhiperformance.com/te...lve/index.html
What Tony is saying is using a bigger rotor in the front than the rear. What you are explaining is what could happen if you use a smaller sized rotor than what is recommended. These are two different points.
OMG.....that was a JOKE !!!!!!
I thought you would laught your *** out when you read my post. But I didn't think you thought that i was serious.
I know but you can't go any bigger rotors in the front without changing to bigger caliper like 6 pistons and so in your car, you can go with smaller rotors in the rear to change % fof the grips. But then too small of a rotors, you might run into problems that I mentioned.
I am already bigger in the front than in the rear. That's what he was saying. I have 355mm in the front and 330mm in the rear. It's not like I'm running 330mm on both.
We know that, but his question were, is there a way we can changed your grip % with your current set up?
By going even smaller rotors then what you have now on the rear. This will reduce the brake pad touching the rotors surface which in turn, create less grip on the rear.
His second question "was have a smaller disk in the rear and bigger one in the front soo the combo
make it more like 60/40 ... ?"
Which is the setup I will have, 355mm front/330mm rear. 60/40 not 50/50 like you say.
You decided to explain what would happen when you change to a smaller rotor than what's recommended which nobody asked.
If you base on just the rotors sizes then I would agreed with you 60/40 but your rear stock caliper is a single piston and now you changed it to a 4 pistons caliper with bigger brake pads. Are you telling me that it would not changed the grip % from a single piston to a 4 pistons with bigger brake pads? You know what, I'm just gonna stop here. This posts started out as to be helpfull but turned in a different direction. At the end of the day, it your car and so do what ever you want and just enjoy it. Have fun, man !!!!!!
Which posts started out to be helpful? Yours?
And believe me Klinh, reading your reply I did laugh my *** off...
