wheels questions
Old Sep 21, 2010 | 07:37 PM
S1KW209's Avatar
08CLK550
wheels questions
I've been searching but no luck here
What is stock wheels offsets and sizes? I have amg pack and they are 18's
for aftermarket wheels, between what sizes are you guys runnung without fender roll or crazy camber?
I appriciate any inputs!
Old Sep 21, 2010 | 07:49 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
The most common wheel size is 19x8.5 front and 19x9.5 rear. The tires are 235/35/19 front and 265/30/19 rear. I am running these now with 10mm spacers all around and have no issues with the fenders. I do rub a bit against the front plastic fender liner on tight turns. That's probably because of the combo of the 10mm spacer, 235 tire, and being lowered on PSS9's.
Old Sep 21, 2010 | 08:15 PM
S1KW209's Avatar
08CLK550
thanks for the input so what is the offset on your wheels?
Old Sep 21, 2010 | 08:35 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
ET25 now with the 10mm spacers. ET35 before.
Old Sep 21, 2010 | 08:51 PM
kevblah's Avatar
E90 M3
would they not have fit with the ET35 offset and NO spacers?
Old Sep 21, 2010 | 09:07 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
They would have (and did) but my BBK wouldn't
Old Sep 21, 2010 | 09:35 PM
S1KW209's Avatar
08CLK550
So it's really depends on the wheel with 35 that can clear bbk in front or not..
Old Sep 21, 2010 | 09:48 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
It depends on your whole setup. Brakes, height of the car, offset of the wheels, size of tires...
Old Sep 22, 2010 | 01:05 AM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
correct.
Old Sep 22, 2010 | 01:34 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
To clear the bbk, you need to look at the size of the rim and the offset of the rim. For example on the AMG 6 pistons, your rim need to be at least 18" not the 17" stock. As for the offset of the rim, I would think you need at least 30 offset to be safe. It all depending on the rim "spokes" design i guess because, mine 19x8.5 rim with 35 offset wouldn't clear my stock front caliper.
Old Sep 22, 2010 | 06:40 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Thanks for repeating what was already posted, what would we do without you.
Old Sep 22, 2010 | 09:03 AM
S1KW209's Avatar
08CLK550
thanks guys it helped me out alot
Old Sep 22, 2010 | 09:51 AM
S1KW209's Avatar
08CLK550
so, would I be rubbing with 19x8.5 +25 and 19x9.5 +25 ?
anyone have 10.5 in the rear? 9.5 is still too narrow for my taste..
Old Sep 22, 2010 | 03:30 PM
lowpost's Avatar
LOL
Old Sep 22, 2010 | 03:36 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
You shouldn't. Will you be lowering the car?
Old Sep 22, 2010 | 03:37 PM
saltydizzle's Avatar
2005 E55 AMG; 2005 CLK 500 (sold)
Just to piggy back on what Wes said, if you run KW V2's instead of the PSS9s, the wheels will most likely hit the coilovers without spacers no matter how low the car is.
Old Sep 22, 2010 | 03:48 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Ditto for the PSS9's...They were almost touching my HD's also.
Old Sep 22, 2010 | 03:56 PM
S1KW209's Avatar
08CLK550
Yes it will be lowered at some point. Not too much though
Old Sep 22, 2010 | 04:01 PM
It kinda depends on how you will be lowering the car. Were you planning on coilover setup or lowering springs?
Old Sep 22, 2010 | 04:10 PM
S1KW209's Avatar
08CLK550
I have not decided yet... What would be good amount for lowering if I want to avoid any rubbing and camber issue?
Old Sep 22, 2010 | 04:14 PM
someone correct me if i am wrong, but i would go with H&R springs. you will still get some negative camber tho no matter how you lower the car.
Old Sep 22, 2010 | 04:19 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Any type of lowering would affect the camber. You could install a camber kit to help out but might have a problem with squeaking. Salty and I both had that problem. I ended up taking the kit off and haven't put it back on. The camber really isn't that bad. I ran the H&R's with the setup you want to run and had no rubbing.
Eibach springs lower 1.2" all around and give you an even drop
H&R springs lower 1.4" front and 1.3" rear. It will look lower in the rear than the front.
Old Sep 22, 2010 | 04:50 PM
S1KW209's Avatar
08CLK550
thanks you guys are making my life easier
I am thinking 19x8.5 +25 225/35/19 and 19x10 +25 255/30/19 ...
Old Sep 22, 2010 | 04:51 PM
S1KW209's Avatar
08CLK550
Or maybe that's too much stretch for rear.
I had 245/35/19 on 9.5 width with no problem so... Lol
Old Sep 22, 2010 | 04:53 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
If you could fit a 265 with the 19x10 in the rear that would be better.
