Knocking sound from front suspension
I have 2006 clk500 with hr swaybars and springs... It's been 20k miles and I am hearing knocking sounds from both side. Everything is tight and swaybar mounts are ok. I heard there is a bearing at the top of the strut, has evenyone heard these getting loose / going bad??? What else could be causing this sound?
Thanks in advance!
Thanks in advance!
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Strut bearing, they do wear out. On another car of mine, when the bearings were worn out it was more of a grindng sound than a knocking.
1 Post
I drive the racism out of BadDebt. ;)
could be a variety of problems....most common being front and rear thrust arms, and tie rods...
the best way to find out is to jack up ur car; remove front wheel and do a manual inspection of the tierods for movement and a visual inspection of the bushings for cracks and leaking fluids.
Clk350 Cabriolet
[jHi.Did you het an answer yo your question as i have a knock on both sides when i drive out of my driveway. I was also thinking it was the top bearing.QUOTE=juhasev;4298277]I have 2006 clk500 with hr swaybars and springs... It's been 20k miles and I am hearing knocking sounds from both side. Everything is tight and swaybar mounts are ok. I heard there is a bearing at the top of the strut, has evenyone heard these getting loose / going bad??? What else could be causing this sound?
Thanks in advance![/QUOTE]
