Need Advice on 20" Rims
CLK350 Sport
I bought a set of 20" Carlsson CR 1/11 with this size
Front: 20" x 8.5
Rear: 20" x 10.5
Tires
Front: 255/35/20
Rear: 275/35/20
It was from an E-class and I think I need a spacer to make it fit into my CLK350.
Please advise me what should I do, what size of spacer should I buy for front and rear?
The rear tires also worn out, should I change the tire size and profile? If I lower my car using lowering spring, will it rub on the fenders?
Thanks guys
Front: 20" x 8.5
Rear: 20" x 10.5
Tires
Front: 255/35/20
Rear: 275/35/20
Thanks guys
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Front: 20" x 8.5
Rear: 20" x 10.5
Tires
Front: 255/35/20
Rear: 275/35/20
Thanks guys![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Front: 20" x 8.5
Rear: 20" x 10.5
Tires
Front: 255/35/20
Rear: 275/35/20
Thanks guys
235/30-20
275/25-20
As Dyno mentioned, you need to figure out what the offset of the wheels are before you pick spacers.
CLK350 Sport
Assuming it's from E-class W211, the front is ET 35 and the rear is ET 33.
Would you think that my CLK will look silly using 20" and not lowered? My city pavement is just horribly bumpy and wavy so I might not lower it.
04 CLK 320 > CLK32K
I am comfortably running 10mm spacers all around with 235/35/19 front and 265/30/19 rear. With the spacer I'm at ET25 all around. The minor problem I have is a bit of rubbing on the front plastic fender liner on sharp turns. Nothing serious.
From experience of 20's for a little over a year...get 19's. In hindsight, I wish I had done that. Don't get me wrong, I love my Vossen's 083 but they would ride a little better and not so "exposed" to potholes, etc.
I had a mishap back in the Spring, two rims were replaced.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I had a mishap back in the Spring, two rims were replaced.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![word](https://mbworld.org/forums/images/smilies/werd.gif)
