Replace Halogen with Bi Xenon
Old Dec 4, 2010 | 07:28 PM
Newjd2's Avatar
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
Do you have any front shots?...I'll probably do this too then and reaim them if there isn't heavy glare light scatter...
Old Dec 4, 2010 | 08:08 PM
Clkboi's Avatar
CLS550 4Matic
Night shots with a camera always show lots of glare when there actually isnt.
ill upload one soon
Old Dec 4, 2010 | 08:14 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Have you considered getting the projector fog lights?
Old Dec 4, 2010 | 08:20 PM
Clkboi's Avatar
CLS550 4Matic
Old Dec 4, 2010 | 09:12 PM
Newjd2's Avatar
Na never thought about it...how is it?...where you get it from?...
And clk that looks great...great color and light output...
Old Dec 4, 2010 | 09:43 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
They are awesome! Much better than the OEM fogs. I have a 6000k HID kit installed in mine. The beam pattern is excellent. I think they are worth the money. http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
Here are some pics. In a few I have one fog light out, but you could get the idea.
Attached Thumbnails Replace Halogen with Bi Xenon-42d0f97b.jpg   Replace Halogen with Bi Xenon-dsc00463.jpg   Replace Halogen with Bi Xenon-dsc00464.jpg   Replace Halogen with Bi Xenon-dsc00471.jpg   Replace Halogen with Bi Xenon-dsc00467.jpg
Old Dec 5, 2010 | 12:44 AM
  #32
Clkboi's Avatar
CLS550 4Matic
Interesting about the output with the projector fogs. I find the halogen housing to have a much more linear line, though the light output is less.
BTW did you end up buying Advans headlights yet?
Old Dec 5, 2010 | 01:45 AM
  #33
dynomite05's Avatar
04 CLK 320 > CLK32K
Nope, still waiting on him.
Old Dec 7, 2010 | 09:39 PM
  #34
csxian's Avatar
CLK350 Sport
For bi-xenon conversion, aside getting the headlight itself, what other wiring harness should I get?
Old Dec 7, 2010 | 09:50 PM
  #35
dynomite05's Avatar
04 CLK 320 > CLK32K
I didn't need any other wiring.
Old Dec 13, 2010 | 06:12 AM
  #36
amusa's Avatar
16 GLE400 4matic
Originally Posted by Clkboi
I use DDM tuning 50W for the headlight and DDM tuning 35W for the fogs.
There is glare yes but it doesn't bother oncoming traffic because i aimed them equally low
Good to know. I just received my 55W 6K with the error box from DDM. I'm about to order the 35W from DDM for my other vehicles.
Old Nov 26, 2014 | 04:57 PM
  #37
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Question,
I just got bi-xenon's for my clk320... which has the halogen stock headlights. Will the highbeams on the projector work? IE: will the cutoff shield open up for those that have went halogen to factory xenon? Or will only the high beams come on while the projector stays as is? OR does both the separate high beam and cut off shield open?
Can't seem to find an answer anywhere...
EDIT:
Figured out that the bi-xenon DOES in fact lower it's shields when the high beam is activated ALONG with the separate high beam on the inside!
w00t w00t!
Thanks,
-Nigel
Old Jan 4, 2015 | 04:34 AM
  #38
GezaBMX's Avatar
2003 CLK240
Hi guys,
I have the OEM lights on my 2003 CLK, was thinking of changing the lights to bi xenon or a nice HID unit. Any suggestions of what should I search for? As far as I understand you can retrofit HID's but you need the lens. Are there OEM CLK HID lights? Or only the halogen on the earlyer models and xenon on the facelift?
Old Jan 4, 2015 | 12:16 PM
  #39
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
HID/Xenon lights were an option for all model years of the W209, so you can certainly find OEM units. You do need to replace the entire headlight assembly to switch from halogen toe HID. The base "reflector" housing of your halogen lights will create a poor beam pattern for the HIDs that will blind other drivers. There are also aftermarket solutions, all of which will use a "projector" style lens. Aftermarket systems can use either halogen bulbs or HID "kits". Note that with OEM HIDs, you will need the car's electronics coded or else they won't work (they will flash and give you bulb errors). Aftermarket kits usually include "error canceling circuitry" so they are plug and play.
I put these on my car:
http://www.ebay.com/itm/DEPO-MERCEDES-BENZ-CLK-W209-2003-2009-CLEAR-CHROME-QUAD-PROJECTOR-HEADLIGHTS-/221259653036?pt=Motors_Car_Truck_Parts_Accessories&hash=item33841a5fac&vxp=mtr
They are nice, but not quite up to OEM quality.
Old Jan 5, 2015 | 12:27 AM
  #40
GezaBMX's Avatar
2003 CLK240
Depo Mercedes Benz CLK W209 2003 2009 Clear Chrome Quad Projector Headlights | eBay
Rudeney, I'm sure you have heard this before but you're the MAN
I didn't know that both HID and Xenon units were available for the whole w209 production run. I have few salvage yards close to me, I might just go there one of these days and see if I could find something nice for a good price since I have the factory Halogen headlights. On other threads I have read about these "Depo" headlights and they do look pretty nice. Is there a factory double projector headlight unit like the "SLR" type or is this just an aftermarket option?
Old Jan 6, 2015 | 12:00 AM
  #41
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No factory option for the quad projectors - just the aftermarket setup.
Old Jan 6, 2015 | 11:57 PM
  #42
TheNoble's Avatar
2003 CLK320
What did you guys replace the high beams with in the depo bixenon headlights?? I saw some members use these:
Amazon.com: Philips H7 12972XVS2 X-Treme Vision Replacement Bulb, (Pack of 2): Automotive Amazon.com: Philips H7 12972XVS2 X-Treme Vision Replacement Bulb, (Pack of 2): Automotive
Anyone use anything else?
Old Jan 7, 2015 | 12:16 AM
  #43
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I used an HID kit. With the high beams on, I have all four projectors with very bright Xenon light that really gives some incredible illumination:
https://mbworld.org/forums/clk-class...ad-xenons.html
The downside is that it takes a few seconds for the high beams to warm up to full brightness, so the "flash to pass" feature is not very "aggressive". However, once they are warmed up, quickly flashing the high beams on and produces a crazy strobe effect that is impossible for the slow moving car ahead in the fast lane to ignore.
Old Jan 7, 2015 | 12:28 AM
  #44
TheNoble's Avatar
2003 CLK320
Wow that looks amazing! Unfortunately I could not purchase the quad projectors headlights as they were out of stock and I needed a pair of headlights immediately =( so I ended up up getting the clk63 style bixenons otherwise I was gonna add an HID kit like you on the high beams in addition to changing the city light
Old Jan 7, 2015 | 12:37 AM
  #45
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Personally, I'd prefer the bixenons, but I got such a deal on the quads, I could not refuse.
Old Jan 7, 2015 | 10:38 AM
  #46
TheNoble's Avatar
2003 CLK320
I'm sure any doubts I have will go away when they are installed!
Did you purchase yours from the fishcake group buy? I'm going through USR right now for my bixenons
Old Jan 7, 2015 | 11:48 PM
  #47
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I bought mine from a fellow MBWORLD member who bought his from fishcake. I beleive he sold his CLK before installing them.
Old Jan 8, 2015 | 04:35 PM
  #48
TheNoble's Avatar
2003 CLK320
lucky! I'm actually in the market for some parts (front bumper cover). Do you just look at the general forum classifieds?
Old Jan 8, 2015 | 11:57 PM
  #49
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That, and sometimes specific forum members will post.
