oil dip stick
Old Dec 7, 2010 | 11:11 PM
S1KW209's Avatar
08CLK550
Originally Posted by 6speedclk
I told you it had one!
yup you sure did. Lol
Old Dec 7, 2010 | 11:54 PM
6speedclk's Avatar
CLK500
Sorry. I didn't mean to sound like a dick. If you do your own oil change it's good to fill it all the way up on the stick. There is no over full warning on your engine but the under full warning can be touchy.
Old Dec 8, 2010 | 12:02 AM
S1KW209's Avatar
08CLK550
No offense was taken. Lol.
Isn't Car suppose to give me a warning if I am low on oil?
Old Dec 8, 2010 | 12:32 AM
6speedclk's Avatar
CLK500
Yes it will. The only resion I say. Is because the old engine (112,113) had a min and max sensor and on the cars that had dip stix you had to be cairfull to keep the oil level right in the middle to compensate for the oil expanding and contracting with tempiture. On the new engines there is only a low oil warning and it's good to fill them all the way up on the dipstick without having to worry about an over full warning comming on in the cluster.
Old Dec 8, 2010 | 11:49 AM
kostas86's Avatar
V8, Flat 6, V6, & Turbo flat 4
Originally Posted by S1KW209
I actually found the dip stick on my car. its located upper(close to windshield) side of the engine.
Check yours lol I have 2008 550.
Thats for tranny
Old Dec 8, 2010 | 02:03 PM
S1KW209's Avatar
08CLK550
Originally Posted by kostas86
Thats for tranny
hahahaha really?
I'd have to double check when I get home I think it was for engine oil..
Old Dec 8, 2010 | 11:18 PM
  #32
6speedclk's Avatar
CLK500
The 550s have 7 speed transmissions that don't have dip sticks. If it were an old 5 speed the tube would have a lock and no actual dip stick.
Old Mar 28, 2011 | 09:58 PM
  #33
Mercedes-Benz's Avatar
CLK 550
Is there a way to check it on a 07 550 using the dash as well? I was reading about some hidden settings for dyno, etc. But, not sure if it applies to my model.
I also added a quart today after driving for 8k miles. I never added a drop in my old c230, lol. But, from what I am reading it is normal to add oil if you run these engines hard.
