CF Interior Pics
#202
yes, the ash tray did say AMG Black Series.
I don't have any plan to do the door trim.
Actually, I replaced them with the other kind of aluminum trim. The patterm of them look like a little bit like carbon. For the window switch cover, I replaced them with painted mat black aluminum trim. I really happy with what I got now.
#205
thanks cannan
#208
04 CLK 320 > CLK32K
I did a test fit today to make sure everything fits and to get an idea of how it looks. The double din is a bit wide. I am going to see if the install shop could do anything about it.
#209
hi bro, sorry 4 late reply, just got back from vegas MFESt.
I dident do the installtion on rolns car. you better of talking to him maybe he can help you. he told me that it fit just fine and i saw it after it was installed. the cf double dins are the same size as the Scosche MZ2347B for c-class, slk and clk. just call me if you need anything alls
323-509-7651
323-509-7651
#210
04 CLK 320 > CLK32K
323-509-7651
323-509-7651
Yea, it should fit the faceilft CLKs. I do remember reading a few people who used that Scosche kit and had the same problem with it being a bit wide. I want to make it work. I will see what the install shop can do about it. I will keep you posted. Thanks for your help.
#211
just got of phone with scosche the double din works on
W203 2005 - UP C-Class
W209 2006 - 2007 CLK
2005 - 2007 SLK
2005 - 2007 SLK
what year is your? please let me know how it gos, if it dosent work just send it back to me and i will refund the money 100% as long as you dont cut it. if you want to see that it will work just try on the plastic double din first they go for $20.
#212
04 CLK 320 > CLK32K
2005 - 2007 SLK
2005 - 2007 SLK
I actually have the plastic one also. Right now the car is in the shop getting motor work done. I don't know when I will get it back, but I will send you some pics when I can. My car is an 04, but I am doing the 06-09 conversion so it's correct. I would really like to avoid returning it. Once I have some more info, I will let you know.
If you take a look at the pic below, you will see that the top of the sides is a bit too wide. The bottom fits good, it's just the top sides that have the problem.
Edit: If all else fails, could I return the CF one and get the plastic one I have modified to fit and then send it to you to get it wrapped?
#216
Hey Dyno, I have a quick question for you. Since you had originally the prefacelift climate control upgraded to the facelifted LED climate control, do the controls work individually?
#223
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
his posts in this thread appear to be his last....I just read all 9 pages, and I kept thinking I would discover a "smoking gun" at some point. Great mod and post, BTW. Did you ever get the radio sorted out?
#224
04 CLK 320 > CLK32K
I don't think he was banned from a post in this thread. He has come back though under several different names.
I got the radio trim shaved to fit, but haven't gotten around to doing the audio install.
#225
I found out about the Audio 20 sizes the hard way myself, when I tried to cram a 203 radio into my 209
I didn't think "shaving" would do the trick, as the screw holes wouldn't line up, and they're fixed
Did you put your old walnut steering wheel up for sale?
