Project CLK32K
Old Jun 29, 2011 | 10:29 AM
  #276
dynomite05's Avatar
04 CLK 320 > CLK32K
Don't know exactly.
You would need the WIS for the wiring diagram. Let me see what I could find.
Old Jun 29, 2011 | 10:34 AM
  #277
user 76208202's Avatar
CLK550
Originally Posted by dynomite05
A funny pic Badblack sent me after he visited the shop.
Old Jul 16, 2011 | 11:37 AM
  #278
MB Dave's Avatar
Suzuki Burgman Executive
bump cause I'm bored
Old Jul 16, 2011 | 01:21 PM
  #279
ahmadk's Avatar
2011 E550 Sedan
+1
Old Jul 16, 2011 | 04:35 PM
  #280
homepukes's Avatar
2000 E320 Original Owner 2007 CLK550 Cabriolet 2015 S600
Peer pressure.
Old Jul 16, 2011 | 04:43 PM
  #281
dynomite05's Avatar
04 CLK 320 > CLK32K
Originally Posted by ahmadk
+1
+2
Old Jul 16, 2011 | 07:57 PM
  #282
Fai+H777's Avatar
ML55 AMG
+7months of waiting
Old Jul 16, 2011 | 09:45 PM
  #283
dynomite05's Avatar
04 CLK 320 > CLK32K
Wow, you have been waiting longer than me.
Old Jul 16, 2011 | 11:36 PM
  #284
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
wait what's going on?
Old Jul 17, 2011 | 02:24 AM
  #285
pacboy22's Avatar
2003 CLK500
I haven't been on here in a while and I just read all 12 pages, even though I haven't waited all those months I'm still anxious as hell man. This is one hell of a project wes its great that your doing something unique mad props to you bro good luck Im sure you'll have her up and running in no time!. BTW bro I finally got my car up and running as well yesterday after all those months =).
You live in jersey right ?...maybe once your done on your car we can meet I would love to see your beast or maybe even a group meet if people are interested!. Good luck once again you did great bro
Old Jul 18, 2011 | 04:45 PM
  #286
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
A member named Pshek did this on a C coupe,
you might want to tap him if yer stuck.
Old Jul 18, 2011 | 04:52 PM
  #287
dynomite05's Avatar
04 CLK 320 > CLK32K
Yup, thanks
Old Jul 23, 2011 | 01:46 AM
  #288
LantanaML320's Avatar
2004 Chrysler Crossfire
Great project. let me know if you are stuck. I can probably help. Mechanically this is an easy swap. Took me 1.5 days to get my V8 in. It took a lot longer to get it to start.
I am editing this now that I read the whole thread. I did not change the trans or diff when I did my V8. I now have about 15K trouble free miles that have included a bunch of very smokey burnouts. Ther is no strength differnce in a C32 diff and the one you had. the only difference is a 3.07 gear instead of 3.27. The key difference in the trans is that the C32 is the same as a V8 trans which has a stonger cluthch pack. Your stock trans has lower gearing. The lower gearing of your stock trans combined with the stock 3.27 rear gear would have helped your 1/4 mile times. the engine in my car has a bit mor torgue than a 32K engine and like I said no trans problems at all. You can swap your lower stock gear set into the 32 trans and then you wouldn't need to change the rear diff or TCU.
I wasn't sure about what you said about using a 320 ignition vs. the 32? this didn't make sense to me. You must use a SLK32 or C32 ECU. Either will work. There are no wirring changes to the engine harness. just make sure everything is hooked up such as the s/c clutch, i/c pump etc.
You do need to verify the wirring going into the the ECU from the body. You simply match by funtion. You need the ECU pinout from your stock ECU and the C32 ECU. WIS sucks for this. I used pinouts from All Data. If wiring is correct you are good to start adapting the C32 to the car.
to program the car you need The MB Star Diagnostic System. I bought a cloned one from China. It runs on a laptop and my total cost was about $800.00 You also need to raise the system to developer mode. You can get a key Gen from JC Recordings for around $25.00 Developer mode is in every SDS system but most MB mechanics don't know this. It takes a special sign in to activate it. Developer mode is used in the factory to build prototypes and make pre-production changes. It is also only in German.
The first step is unlock the C32 ECU. Beckmann technologies does this for about $250.00 **Once unlocked you have a limited amount of time you can turn the key before it locks again**
Next, Install the stock ECU and print out all the current values. It will give you things like gear ratios, tire sizes etc. You will use these values to program the C32 ECU.
With the unlocked ECU you then have to enter the system by using SLK32 or C32. You cannot specify CLK since your engine never came in a CLK. I used CLK500 to program my car. Prgraming your ECU should be much easier than trying to get the system to accept a Chrysler VIN number as in my case.
check everything such as tire size, gear ratios etc. and make changes if needed to match what you actually have. go to actual values and make sure it is reading your transmission. It should say P for park and change as you move the shifter. If it can't verify park, the car will never start.
The next step is easier for you than for me since your car is an EZS car and you can run EZS to get your donor ECU to learn the anti-theft data. If everything is wirred right, the actuall programming shouldn't take more that a couple of hours by someone who knows the SDS system in developer mode.
Since your car in not running yet, I am sure the issue is with programing. I hope this helps. don't worry or get down as this can be done. You also have the option of getting extra help if needed. RCompart on the Crossfire forum has already put three 55K egines in Crossfires and did the programing for a member here who put a 55K in his CLS500 show car.
Old Jul 23, 2011 | 02:22 PM
  #289
dynomite05's Avatar
04 CLK 320 > CLK32K
Wow, you will definitely be hearing from me soon. Thanks for the help.
Old Jul 23, 2011 | 02:35 PM
  #290
Velociabstract's Avatar
SRT-6
I'm glad you found this thread Lantana. I was thinking you could help out if needed. Best of luck dynomite05.
Les
Old Jul 23, 2011 | 06:03 PM
  #291
Les
Hey Les! good to see you over here. I found this thread when I started thinking about building a really fast CLK convertible. We have exchanged some Pm's today and Wes's car will run soon.
Old Jul 26, 2011 | 01:09 AM
  #292
6speedclk's Avatar
CLK500
When I was putting the six speed in my clk 500 I had rentech make the modifications to my ECM programing. Wich was only slection changes after it was unlocked. It only took a day with over night shipping. You may want to give them a call and tell them what your up too. Thay seemed pritty nice. $450 with no tune.
Old Jul 26, 2011 | 02:19 AM
  #293
lowpost's Avatar
Good looking out fellas!
Old Jul 26, 2011 | 09:50 AM
  #294
Jamesbbh's Avatar
2006 Facelift CLK500 Cab-
Just go down there and rough him up with a wiffle ball bat.
Old Jul 26, 2011 | 10:12 AM
  #295
dynomite05's Avatar
04 CLK 320 > CLK32K
lol, Hopefully we're on the right path to get this issue resolved. Thanks for all the help!
Old Jul 26, 2011 | 11:41 AM
  #296
WaveyKat's Avatar
Something Slow
hey did you give my guy a call?.. :-)
i posted some updates here
https://mbworld.org/forums/c-class-w...stions-25.html
read from Post #624
Old Jul 26, 2011 | 01:46 PM
  #297
kostas86's Avatar
V8, Flat 6, V6, & Turbo flat 4
hope to hear it's running soon!
Old Jul 26, 2011 | 08:04 PM
  #298
read from Post #624
Who's your guy?
Old Jul 26, 2011 | 10:06 PM
  #299
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
All that was waaaaayyyy over my head. What a great group to be a part of.
Old Jul 27, 2011 | 09:22 AM
  #300
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Nice to see some new info on this thread, sweet Crossfire conversion! Saw one here in Dubai with the same swap just a few days ago, car was imported from the US.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
