DIY aftermarket Amp/Sub with Stock HU
Some instructions here if they could help. I am still waiting on the new WIS, so I don't have access to check.
http://w209forums.com/showthread.php...all-Rear-Shelf
Andy
Andy
Next question - are you putting the sub in a box or mounting it in the factory sub location (aka, removing the factory sub)?
Edit: im about to leave the house to check on that "harness". Lets just hope they have it .
Andy
If you can't find a harness to fit the plug on the amp, you still have no problem, this is a trick we've all done before and it works just the same. Take some small barrel connectors and gently crimp one end down a little at a time and slip it over the line level in pin until you have a nice tight fit (you'll have to slip it on and remove it and use a gentle crimp a few times to get it nice and snug), then fit your twisted pairs into the other end of the barrel connector and give it a tight crimp. Voila! You just put together a home made harness. Plug the barrel connectors into the correct places and put a bead of silicone around them - doing this 'glues' them to the amp so they wont accidentally fall out but they can still easily be removed later.
. Will report back when its done. Hopefully, i can get it done today. AMG airbox and the car are done, i am ready to roll with a new system
Kev, do you know anything about those wire colors ?
Wes, do you think you can check on EPC for the color code ? If you need the VIN let me know man.
Andy
Now the reason it takes me all day to do this because i didnt know there was something wrong with my aftermarket amp ( i never buy a used amp again on ebay
) I hooked up everything but there was no sounds at all ...i kept trying and trying for like 4 hrs but nothing better. I finally went to my honda and get my crappy amp out and test it in the car with the sub and just works fine
. Anyway, the color for the sub wires are purple/brown (-) and purple (+). Like i said above you dont have to go to your stock amp but get back to the rear seat and open the cover it is there you can see it. Alrite i guess thats it for today so tired. Any questions will be answer later but now im fcking starving
Dollar for watt they are tough to beat
http://www.kenwoodusa.com/Car_Entert...iers/KAC-9105D
Monster power for very low cost. The 8150 is also a ton of power and cheaper. Myself and another member on the forum are going to be using their eXcelon digital amps.
