Need some feedback on a tire size.
Old Feb 17, 2011 | 10:11 AM
chrislis's Avatar
2005 CLK500
the sidewall effects the rub just as much as the width. if you run a 35 rear you WILL rub. if you run a 30 it will be minimal, and most people run 35's because of price. just putting it out there. 265/30/19.
Old Feb 17, 2011 | 10:16 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
I didn't rub in the rear when I had ET35 using a 265 tire. Two different sets of wheels and no rub
Old Feb 17, 2011 | 10:22 AM
chrislis's Avatar
2005 CLK500
not offset, sidewallllllll. but at et35 you won't rub, im referring to going flush fitment. anything remotely close to 25 and under will rub at a 35 sidewall.
Old Feb 17, 2011 | 10:55 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Ohhh, my bad I thought you were talking about ET.
Old Feb 17, 2011 | 10:56 AM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Same here.
Old Feb 17, 2011 | 10:58 AM
Mka77's Avatar
I'm sure Wes and I are talking 265-30 here, not a 35 series.
Old Feb 17, 2011 | 12:40 PM
  #32
Supafly's Avatar
I drive the racism out of BadDebt. ;)
Originally Posted by 2MCHCAR
What size fronts are you running? Any ESP lights going off? And so I understand correctly you have an ET35 now (Wheel ET50 - Spacer ET15 = ET35) with a little rubbing in the rear, are you lowered too?
sorry, I mis-informed you guys. I took off my rear wheel lastnight to confirm the offset. It is originally ET45..and with the adittional HR hub adapter at 15mm; that makes the overall ET of 30now.
Im still lowered on HR Springs with the pad #2. She only rubs when I hit super big dips on the road, but that might be due to my aging struts that need to be replaced soon.
My fronts are 235/35/19. I also have spacers up front, iirc they are HR 10mm...I cannot remember the offset of the front wheels.
Front rims are 235/35/19 - 19x8.5
Rear rims are 275/30/19 - 19x10
No ESP lights or malfunctions yet. The only problem i seem to run into is that with the wider stance, the ride seems to track a bit when theres grooves in the road.
I'll snap some pics tonight to show you guys how flush it is sitting atm.
Old Feb 17, 2011 | 12:46 PM
  #33
Mka77's Avatar
Look forward to seeing the pics tonight.
Old Apr 17, 2011 | 10:18 PM
  #34
Supafly's Avatar
Originally Posted by Supafly
Im currently running 275/30/19s in the rear with ghostriders camber kit, 15mm hubadapters and rolled fenders. my offset is 35. You will def need to roll your fenders and throw on your spacers/hub adapter to avoid rubbing against your struts/liner. Tires are Hankooks v12s.
I've done alot of DIY work on my fenders just to make them fit properly.
Hey guys...reviving an old thread with some pics....finally got around to them after a month or so...
Attached Thumbnails Need some feedback on a tire size.-1.jpg   Need some feedback on a tire size.-2.jpg   Need some feedback on a tire size.-3.jpg   Need some feedback on a tire size.-4.jpg
Old Apr 17, 2011 | 10:28 PM
  #35
Mka77's Avatar
Looks great fly. I should have trusted you and went with the 275's even with all saying don't do it. That's FAT!
Old Apr 18, 2011 | 11:27 AM
  #36
chrislis's Avatar
2005 CLK500
post pictures of your car pleaseeeeee. need fitment visions.
