CLK320Cdi (w209) -06
Old May 7, 2011 | 05:59 AM
ChiquitaTinker's Avatar
W211 270CDI
Hello,
is the interior ligth unit, part nr A 20982022019051 and A20382082019051 compatible?
How about 20982022019051 and 20982011017E9??
Thank you in advence for Your promt response!
Old May 7, 2011 | 09:52 AM
Fai+H777's Avatar
ML55 AMG
[Insert Dyno's comment here]
Old May 7, 2011 | 10:06 AM
M-bENZ's Avatar
Corrolla
Lol
Old May 7, 2011 | 10:30 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Originally Posted by ChiquitaTinker
Hello,
For the 320 CDI the EPC lists both 209 820 22 01 & 203 820 82 01. The 9051 that follows is the color code. 9051 = Black.
As for part number 209 820 11 01, it only lists it for the following vehicles. Also 7E94 is the color code for Alpaca Gray.
Ha.
Old May 7, 2011 | 10:56 AM
W211 270CDI
Dynomite,
if I got it right, for WDB2093201F170975 the A2098201101(7E94) would not be the right one.
Any idea what could go wrong with that part in that body..?
Reason I'm asking is that I could by a second hand part with that number with 70 eur while local MB dealer is asking close to 480 eur (!) for a new part. Should I just keep on hunting..
Old May 7, 2011 | 11:02 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Dynomite,
Based on your VIN, you need a black one. Part number 2098201101(7E94) is gray. I'm sure you could buy it, but it won't match. Also keep in mind that different lamps might come with different options.
Here are the part numbers the show up with your VIN.
Old May 7, 2011 | 11:57 AM
W211 270CDI
the grey color would not be a broblem, the old, black frame is ok and can be retorofitted form old unit to new I believe.
In my lamp unit is autoclima tepm.sensor having a failure. I presume it's not possible to get just the sensor as a spare, is it? (I know from MB not)
Old May 7, 2011 | 12:06 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Probably not.
Old May 8, 2011 | 11:43 AM
W211 270CDI
Hi Dynomite!
Thanks for this new number: 203 820 82 01 now I did find a second macth and need not take any risks!
I've also an ohter smal problem, 404 Multi-contour seat, front left
405 Multi-contour seat, front right their adjustments are not working. We were scanning the whole car with 'star' but we did not find any fault messages. Actually we did not find the whole seat system either.. ?? Wiring, piping controls and vacuum pump they're installed. Fuses in back SAM are there. (9,13). What might be the reason..??
