Bilstein PSS9 - finall
Old May 21, 2011 | 04:13 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Looking forward to that also. Looks like, bit by bit, everything is coming together.
Old May 22, 2011 | 07:34 AM
dariusf's Avatar
2023 CLA 250, 2021 GLC43, 2003 CLK320
Yes, I'm taking it slow. Too little time for things like the car. I just got about a dozen vinyl samples for the wood wrapping I want to do while I have everything apart for the audio overhaul. Thinking black semi-glossy fiber looks best for the black interior. At first I wanted to go with some brushed metal in silver or gunmetal. But it looks a bit fake. Still considering the brushed titanium one.
http://cgi.ebay.com/ebaymotors/3M-Sc...Q5fAccessories
Old May 23, 2011 | 10:08 AM
dariusf's Avatar
Ok, I adjusted the stiffness on the fronts. It was turned all the way so I turned it all other way. Took it for a test drive and it feels much better. Still stiff but not much more then it was with the stock suspension. The rear I believe is on the softest setting. So far I'm a happy camper. the car also looks much better from the front lowered like this. Much more aggressive
Old May 23, 2011 | 10:55 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Looks really good dude, going to be a nice build when you're all done.
Old May 23, 2011 | 12:29 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
Much better!
Old Jun 7, 2011 | 01:58 PM
user 76208202's Avatar
CLK550
Looks amazing. Have you measured what your gap is from hub to fender? The back looks dumped
PS, are you on 18's or 19s?
Old Jun 7, 2011 | 02:04 PM
  #32
dariusf's Avatar
are you talking about my back wheels?
I run 19"
Old Jun 7, 2011 | 02:11 PM
  #33
CLK550
I run 19"
Ya, it looks good. Perfect stance
Old Jun 7, 2011 | 02:25 PM
  #34
dariusf's Avatar
cool thanks, I know the pre measurements but did not measure the after, I will try to measure today if I remember and post it here.
The wheels are
Monarch EURO 63 RS
19x8.5 32mm offset - 3mm spacers = 29mm
19x9.5 35mm offset
tires
225/35/19 Toyo FZ4
255/35/19 Bridgestone Potenza RE050
I'm waiting on 10mm spacers for the rear. Should be here any day. If it fits the rear will look much better from the sides.
