Best Way to Add iPod/Bluetooth to my 2006 CLK 350?
*in my wife's 2007 E350 with the OEM iPod cable in the glovebox, the artist/title info DOES appear in the MFD, but there's no way to control the iPod while it's connected, e.g. you can't scroll playlists.
I did some research on the apple 30 pin to lightning adapter and it seems that they are hit or miss when it comes to car audio though the consensus is that it should work for audio but definitely not video. I also am not clear on how the iPod cable works, if it would replace the AUX input mode for the headphone jack or what. I think it will be best if I also just do the AUX headphone jack input as forward compatibility will continue to be a problem in the future as new connectors are introduced, whereas the headphone jack will endure time much better (though bluetooth audio may hurt that). I actually have an extra iPod I could just keep in the car, but it would be a hassle to keep updating it with new music. I'm not after storage capacity as much as keeping current music available, which is most often found on my phone.
Oh, and to select playlists, you use the phone buttons on the steering wheel. It's covered in the manual.
Actually, can you have both? I presume not because they both operate on the AUX input.
