Broken trunk partition CLK 320
Any info on replacing or fixing is greatly appreciated!!
Thanks!
Thanks!
BTW, like a previous poster, I too note that the resistance offered by the new struts is significantly greater than it was prior to the struts replacement, so I know that some good has come from what has been accomplished. But i still can't put my top down!!!
hi, hope all is well.i wanted to know, if you did get your top to open. i am experiencing a similar issue to yours's, after replacing the gas struts?
thanks
I have a 2008 CLK 550 and had been getting the "Trunk Partition Open" warning for some time but was able to correct it after resetting the partition down, in its place.
I take c-r-a-p in and out of the trunk often.
Now it will not stay fully seated, depressing the switch, and it seems as though it is as simple as replacing the struts but I have to first ask: Does the trunk lid need to be closed for the top to operate?
(Note that I have depressed the switch, where the partition seats, on the drivers side, w/lid up, to try and lower the top but I continue to get the same error msg.)
Thank you for any additional help and best regards,
L
Thank you RussWhite/all.
Then I tried the link http://www.spdhardware.com/ but get the error code 403 - Forbidden: Access is denied."
A google search of the part number given gave an Amazon link to the following:
https://www.amazon.com/dp/B002UC1B2C...I1LLD8Y5M8L9TX
Look about right?
Best, L
http://www.ebay.com/itm/2x-STABILUS-...Gia7#vi-ilComp
http://www.ebay.com/itm/NEW-Mercedes...1UrT2v&vxp=mtr
https://www.amazon.com/Partition-STA...rtition+strut#
Got the strut number off the original strut and googled it. Several parts house had in stock for half the MB price. Ordered from Autohausaz.com they matched my clk part.
Will install next week. This strut hold both the partition open and closed.
Thank you MB world.
I have come across many threads that solve convertible top problems for CLK - eg boot lid closing problem and gas cylinders to hold the switch to close the top and others, however my problem is alittle different.
The top is actually now open, and I receive "top visit workshop" message and fails to close. Last year I had a complete overhaul of the hydraulic system which costed close to a fortune!
Thinking #1:
I thought there would be a problem in the boot partition lid as I have received messages before to close it even though I made sure it was, I tried to tape the switch (small switch left hand top corner on boot partition) and keep it pressed, did not work.
Thinking #2: I read in owners manual how you can reset the top operation by removing and reconnecting the fuse / jumper #28 (side fuse box), did not work.
Thinking #3: I disconnected the battery for some long time hoping it would reset any system faults and then I will be able to operate the top, failed.
Thinking #4: I disconnected the battery, removed the convertible top fuse, connnected the battery after some long time, connected the fuse again, failed.
Ps, During this I switched the car on before reconnecting the fuse, and I had a red warning message - Please release the rollover bar...
Thinking #5: I thought I would try to manually close the top as per the owners manual (removing the panel behind the center top indoor lights then use the allen key placed inside the owners manual case etc..) I could not remove that panel..
Hence, my top is still up and I really appreciate any advise or sharing previous experiences to help me close the top again.
Thanks and regards...
Thinking #1:
What I meant was the roof is down = open.
Now the panel, please forget about what I wrote, I was actually looking at the mechanism to slide open the sunroof (which I do not have) again, drowsy mistake!
I saw the video below which suggests another way to manually close the top..
http://benzbits.com/w209/soft_top/ManualClose.wmv
[Thanks to Rudeney who posted this earlier]
I will try to close the top manually and see if this would reset the switches back to normal state.
do you think this could work? any suggestions on the error message I have "top visit workshop" and how to erase it?
Thanks again.
