Transmission fluid drain/fill
Old Jul 7, 2011 | 09:38 PM
clkmb's Avatar
2003 CLK500
Does anyone who has successfully changed their transmission fluid have any guidance or tips then can give to someone who has never done it before? Where can I find the plug to drain the old fluid on the w209? Where does the filter go? I found the right filter/gasket parts and the fluid but I wasn't able to locate any concrete information about a DIY transmission fluid change on the w209. Thanks.
Old Jul 7, 2011 | 10:35 PM
ambit's Avatar
09 CLK550
I changed the filter on my 2005 CLK55 AMG last week.
Drained what I could from the torx bolt on the bottom of the tranny, was about 3.1Qt.
Removed the pan via the 6 allen-key bolts. The rear, passanger side bolt had a small heatshield-looking thing attached to it.
Drained the pan and pulled off the filter. About another 0.2Qt came out.
Clipped the new filter in and put it all back together.
Took about 30mins.
The tranny fill tube is in the very back of my engine bay by the oil tube. Had to break the red tab off the black cap to open it. SLOWLY added 3Qt of MB Auto tranny fluid. Took it out for another drive and added the remaining 0.3Qt.
That was about 500mi ago and no issues.
Fluid that came out was nasty but not terrible. 46,000mi on it.
Note: This doesn't flush everything, there is another couple quarts in the torque converter. You could drain that too but its a pain trying to find the drain plug through the bell housing. You'll need someone to turn the engine over while you look from underneath.
Old Jul 7, 2011 | 11:13 PM
12secCLK's Avatar
clk55
i would recommend to only let mercedes dealer to do any kind of trans service there are some extra steps you need to do that you just cant do with out mercedes computers.
Old Jul 8, 2011 | 04:34 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Yup......only a few didn't have any problem DIY afterward but alot people reported problems with hard shifting. The tranny service is the only service i paid Mercedes to do on all Mercedes i owned because Mercedes check and recalibrate valves body pressure within spec. after service done.
Old Jul 8, 2011 | 06:27 AM
12secCLK's Avatar
clk55
i learned the hard way by letting an independent shop do it and now i have clutches burning up.
Old Jul 8, 2011 | 09:12 PM
billyhead1's Avatar
CLK 320
There's a DIY out there on trans fluid change/flush from someone who did it to their W203 (?) coupe - the hatchback. You'll just have to search.
Old Jul 9, 2011 | 11:18 AM
elijah's Avatar
Euro Cars Only
I had my MB dealership do that 2 weeks ago. I thought about doing it myself then changed my mind. Leave it to the pros. Cost me 400. Then again they did a complete drain, changed all fluids and now she is running extra smooth.
