W209 (aftermarket) bi-xenon lights coming soon....
Old Jan 30, 2015 | 02:42 PM
  #551
TheNoble's Avatar
2003 CLK320
Hey is this little cutout part on the bottom of the projector lenses normal??
Old Jan 31, 2015 | 05:03 AM
  #552
DanielFD's Avatar
2007 BMW 550i
it looks normal to me.. somebody with bixenons will have to comment on that. the way its bent over that hole(looks like a screw hole), I'd say its normal. interesting how did u even notice that??
Old Jan 31, 2015 | 07:37 AM
  #553
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
Condensation drain hole?
Old Feb 2, 2015 | 10:54 AM
  #554
TheNoble's Avatar
2003 CLK320
I was just inspecting the front of the vehicle and noticed them when looking at the headlight . Just wanted to make sure that was normal. I think you're both right above it being the condensation drain hole
Old Mar 30, 2015 | 12:34 PM
  #555
j3leung's Avatar
Blub replacement
HI all, I have been thinking about replacement my blubs since one side look blue and their other side is starting to look more orange. Does anyone know how to tell what type of lighting i have on my CLK?? My ride is 06 CLK500 and I got it used. I don't know how to tell if it is xenon? bi xenon? HID?
Old Mar 30, 2015 | 01:09 PM
  #556
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow
The factory hella projectors use D2S bulbs. Does your headlight look like the above posted picture or does it look like a stock reflector housing? If reflector housing the bulb is H7. At which point if you want something brighter go with:
http://store.candlepower.com/osraulhiouh7.html
Before I did the projectors on the merc my reflector housing I used the Osram for both high and low... it was extremely good light output. The extra 15watts don't make a problem either.
Go to retrofitsource.com. They have several options available. IF you have projector (HID)
http://www.theretrofitsource.com/components/bulbs.html
I believe factory uses Osram bulbs. I went with Philips mainly due to the fact that the factory Osram bulbs start to turn pink after a while as they color fade and looks bad to me. $100 for the bulbs or you can drop almost $200 for the absolute brightest Philips/Osram ones... 3200 lumens. IF you want the most like look at the Osram nightbreakers, I think they are rated at 3500 lumens...
I can't see spending $200 for D2S bulbs so I went with the normal Philips 85122. This seems like my go to bulb for my STi that has a projector retro fit in it, my truck and the Merc... Never had an issue using OEM Philips.
-Nigel
Old Mar 31, 2015 | 12:47 AM
  #557
j3leung's Avatar
This is my light, I believe its DS2 blub then?
Old Mar 31, 2015 | 07:52 AM
  #558
mrbobby's Avatar
The first thing I would do is to change the bulbs from one side to the other. If the bulbs stay the same colors but on different sides then you have a bulb problem. If the bulb movement doesn't make a difference then you have a ballast problem.
Old Mar 31, 2015 | 11:28 AM
  #559
j3leung's Avatar
Great idea. I will check it out tonight... is the operation to switch the bulb quite simple? is there anything I should be mindful of when I change the bulbs? Thanks
Old Apr 1, 2015 | 08:47 AM
  #560
mrbobby's Avatar
No, it's pretty simple. All is accessible from the back of the headlight unit. Changing the ballast will require removing the guilty headlight. Good luck
Old Dec 23, 2016 | 02:33 PM
  #561
TheNoble's Avatar
2003 CLK320
Has anyone re-fitted the bulbs and ballast that came with the USR Depo headlights? I'm getting some flickering upon startup on my left side and I think the ballasts are about to go bad (not that they were that good in the first place).
