Check engine light on after replacing sway bars ??
Old Aug 13, 2011 | 02:30 AM
mi_clk550's Avatar
CLK 550
Hi Guys.. newbie to the forums and I need some help here..
Something strange happened when I swapped my front / rear sway bars out.. I know have my check engine light on. I'm certain it was off prior to the project.
Is there a remote possibility that when I had the car jacked on the front (then on the rear) in an angle something happened ?? i'm lost here this total does't make any sense to me.
Any feedback would be appreciated...
Tnx
TC
Old Aug 13, 2011 | 08:57 AM
Yidney's Avatar
2008 CLK550 Cab
Not likely, but anything is possible, but whether you caused it or not your first step is to read the codes so you know what is triggering it.
Old Aug 13, 2011 | 09:59 AM
abiazis's Avatar
SL 65 AMG, Porsche 911 (993), 2014 Cayenne GTS, 2013 Toyota Highlander Limited
Same happened to me
Coincidence......have the codes read.....
Old Aug 13, 2011 | 12:35 PM
bheng's Avatar
2003 CLK 320
agreed. the only think i can think of is that you hit the o2 sensor when installing the sways causing the code to be thrown. my friend did that on his car (non mercedes) so its a possibility.
Old Aug 13, 2011 | 05:29 PM
KENNY94945's Avatar
Access and read the code...please let us know.
