H&R 5mm Hubcentric Spacer (anybody get no vibration)
Old Oct 5, 2011 | 12:50 AM
gstar1988's Avatar
2006 Clk 500
anyone have them mounted on the fronts? Some threads say they arent true hubcentric spacers but i just want to know anyone have them and have no problems with vibration.
Old Oct 5, 2011 | 01:29 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
g - there are no such thing as commercially available 5mm hub-centric spacers. I have ran them, they gave me vibrations, I swapped them out to 10mm spacers and got none.
*** edit ***
I just saw that you posted in your other thread that you have already installed your 5mm front spacers - are you getting vibrations? If you are then it's a problem, if you aren't then it's all good and it doesn't matter if others (including myself) are or not.
Old Oct 5, 2011 | 07:30 PM
gstar1988's Avatar
2006 Clk 500
yeah they vibrate.. order the H&R 10mm.. cant find a store that has them in stock! Hopefully after i get these spacers i can finally stop worrying...
Old Oct 5, 2011 | 10:44 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Try to re-align/mount the wheel by hands. Mine vibrated too but I got it to stop by re-mount the wheel by hands.
Old Oct 6, 2011 | 12:47 AM
gstar1988's Avatar
2006 Clk 500
Yeah, will also clean the surface with a wire brush.. What is the correct torque 80 ft lbs?
Old Oct 6, 2011 | 03:55 PM
bheng's Avatar
2003 CLK 320
i thought it was 96 or something?
Old Oct 6, 2011 | 04:57 PM
EuroTra$H's Avatar
19 C300
5mm are nothing but problems, go with 10 or none
