w209 2004 transmission downshifts all the way even with one tap on the (-)
Old Oct 12, 2011 | 08:06 AM
abu_gaby's Avatar
c230 kompressor sport sedan - Sold, CLK200 Cabrio 2005, E200 2009 Sport
Exclamation w209 2004 transmission downshifts all the way even with one tap on the (-)
Hello guys hope you could help me out with this, i just bought a CLK200 2004 w209 Cabrio and i am trying to figure out the problem with the gearbox, when i try to downshift from D to 4 the car downshifts all the way to 1 instead and i am not holding the stick to the (-) just one tap does it.
Is there a way to reset it? or what is the problem with it? was i dooped into buying a lemon???? any help or suggestions would be helpful.
Another side issue the command keeps switching to radio when i am using the changers very weird.
Old Oct 12, 2011 | 08:32 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Try doing an ECU reset, my C200 had the same issue. I actually had to do a hard reset to clear it out but try the ECU reset first.
Old Oct 12, 2011 | 08:33 AM
abu_gaby's Avatar
tried the soft reset the one with the pedal no luck, how do i do a hard reset
Old Oct 12, 2011 | 09:23 AM
Kevwood's Avatar
Disconnect the battery for 30 minutes
