Third brake light on even w/ no key in ignition? Help?
2003 clk500 (w209)
I just replaced my cracked third brake light on my w209 2003 clk500 using the posted DIY and OEM replacement from autohausaz, which was a very easy job. Unfortunately now it seems as if the third brake light stays on ALL the time even without the key in the ignition. I'm not sure if this is a fuse problem? Or what it could be. Everything was pretty easy plug and play. Would somebody be able to lead me in the right direction ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
2009 CLK 550---2008 BMW 335i--2006 SLK 350----1996 Acura NSX ---- 2000 CLK convertible---1997 BMW M3
2003 clk500 (w209)
<b>Third brake light constantly on
What is the SAM? Tried disconnecting the ground cable, and no go. The third brake light is disconnected for now, which is the only way to turn it off, but I would definitely enjoy finding a solution without going to the stealer-ship or some narrow mechanic. Any hints? I checked out the wiring, and all looks generally healthy except a hairline opening (I'm talking micro-tear of the wirecover of one of the brake light wires. Less than the thickness of a hair) But the wires inside look perfectly fine and in good condition. Just wrapped it in a shred of elec. tape??? What can it be
Do you replaced the old one due to crack len or it stop lite up? If you old one still work, try plug in the old one and see if it change. I think there might be a short some where inside the new part. I personally replaced mine and my friend Clk without any issue.
MBworld Guru
The rear SAM is actually underneath the rear fuse box. I would second Klinh's suggestion - try the old part to eliminate the problem being within the light assembly itself.
