help - after cps install still dead ! malfunction
Old Nov 26, 2011 | 07:20 AM
jannickj's Avatar
Hey Everybody,
clk500 died 3 times on me while driving !. i had it towed 2 times. the display says malfunction and all light and check engines in dashboard is on and the fuel meter says empty. Normally i could start the car the day after. I read every possible tread here on errors. everything pointed in the edirection of a crank shaft sensor. the last time it stalled, i could not start it up again the day after...
I ordered a cps and installed it. at the same time i cleaned the maf.
But the car still won't crank up !! i have a completely new key.
my electronics is bad as well after this.
I can't operate my roof
I can only open and close the doors with IR close to the handle.
Any help would be appreciated. I tried to disconnect the battery for a whole night.
Nothing changed.
Any fuse i can try to pull out ?
reset computer ?
Old Nov 26, 2011 | 07:48 AM
betrezra's Avatar
C63 507 AMG DA Car #19
How old is your battery? Check voltage, put on trickle charger if low, then try to start.
Old Nov 26, 2011 | 10:24 AM
jannickj's Avatar
its not the newest battery. after these earlier engine stall i discharged my battery, so it has been almost done to zero. But i charged it a couple of times on "turtle" mode. - i have 12,9 voltage on it now after several start up test.
But i will try to charge it again. this moment.
Old Nov 26, 2011 | 11:05 AM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Battery sounds like it is done.
Old Nov 26, 2011 | 07:04 PM
jannickj's Avatar
as long as it can supply 13.2 voltage it should not be that problem for testing purpose. The inboard mercedes service says 13,2 v now. and still same error
Old Nov 27, 2011 | 09:34 PM
Newjd2's Avatar
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
Did you plug your car with an OBD II scanner? Was that the original code it threw? Did you clear the codes?
Angelo
Old Nov 27, 2011 | 10:04 PM
jannickj's Avatar
yes i did !.. 0 codes*- like totally dead.
but
GOOD NEWS !!!
i took every fuse apart in the whole car.... cleaned everything with CRC electric cleaner !
and guess what !.. when i turned the key it started !!.. Amazing ! people around me ( mechanics) told me i was crazy spending time on that.
i suspect it was from one of the fuses in the trunk, as i think i heard a small click at one of them.
So a loose fuse/dirt !... At least i got a new CPS sensor and cleaned the maf !
thank you all for your response
