100K service...
Old Nov 30, 2011 | 06:48 PM
ludwig14's Avatar
2016 C63s
Exclamation 100K service...
Guys,
I will be doing a service this weekend since the car is about to hit 100k miles. Are the wires a must? How about the plugs? I haven't changed them since I bought the car at 58K. If so, please help me with brands and a site(s) I should order from.
Any thing else I should look into replacing?
Thanks for all your help!
Old Nov 30, 2011 | 10:12 PM
bheng's Avatar
2003 CLK 320
you can get OEM (Bosch) or some members use NGK plugs.
you can also switch out your wires too. I think the company is called magnacore?
hopefully someone with actual experience can chime in. im about to do 100k service too currently at 94k
Old Nov 30, 2011 | 11:26 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Check out www.autohausaz.com
Their prices are really decent
Old Dec 1, 2011 | 05:00 AM
Newjd2's Avatar
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
Don't really have any recommendations, but I am curious to know how your cars are still running at 100k?...
Angelo
Old Dec 1, 2011 | 02:33 PM
ludwig14's Avatar
2016 C63s
Newjd2- At this point I really haven't had too many issues. I had all the gaskets and seals replaced under extended warranty. Motor mounts replaces and the sway bar end links as well. Transmission was overhauled earlier in the year as well. Other than that it's been smooth sailing...
Old Dec 1, 2011 | 02:34 PM
ludwig14's Avatar
2016 C63s
Thank you MKA77!
Anyone have experience with Karlyn-STI wire set??
Old Dec 1, 2011 | 06:48 PM
bheng's Avatar
2003 CLK 320
main problem i had was my tranny was overhauled at 50k but that was because of the coolant leak.
other than that, normal wear and tear. a couple of broken parts i need to fix. and my ps is leaking quite quickly, i will need to reseal it over christmas time when i have access to a garage. might have to replace the whole unit (but if thats the case, i might bring it to an indy)
Old Dec 2, 2011 | 02:37 PM
ludwig14's Avatar
2016 C63s
Bump- Anyone use Karlyn wire set??
Old Dec 5, 2011 | 07:02 PM
ludwig14's Avatar
2016 C63s
Bump
Old Dec 5, 2011 | 08:15 PM
Glyn M Ruck's Avatar
Super Moderator
Only replace wires or coils if you are storing misfire codes after new plugs. Plugs are due. Don't forget the fuel filter if it has not been replaced in a long while. Otherwise just do what the book says.
Old Dec 6, 2011 | 01:15 PM
ludwig14's Avatar
2016 C63s
Thanks bud! I was thinking the same thing...
