Improving radio reception using other antennas
I just upgraded my non-COMAND 2007 CLK W209 Cabriolet with a Pioneer AVIC-Z130BT double-din navigation unit.
In general, I love it. Great navigation interface, built-in traffic, voice control, Pandora from my iPhone over Bluetooth, etc etc.
Strangely, however, the only thing that has gotten markedly worse after the upgrade is AM/FM radio reception. This is still pretty important to me. Reception was probably a "D" when I got it back from the installer. I called and brought it back in and they moved the antenna or something and now it's maybe a C+ on a good day and a C- on a bad day. Not exactly listenable.
The installer said the car has 5 antennas... all embedded in the glass, and aftermarket radios don't have access to them. Is this true? If so, is there anything else I can do to improve the situation? Is there some kickass aftermarket antenna I need to buy or something?
Thanks.
Thanks.
As far as I know, our cars come with an antenna connection different than what would go in the aftermarket headunit. So when your installer says that the headunit doesnt have access to the car antennas, I'm assuming your pioneer isnt connected to the OEM antenna right now? If so, you probably just need to get an adapter:
http://www.ebay.co.uk/itm/2706373225...ht_2160wt_1270
or this one (if you want both FM and AM):
http://www.ebay.co.uk/itm/Dual-Doubl...ht_2282wt_1270
Perhaps you could check with your installer first if he's using these in your car already.
MBworld Guru
I replied on benzworld also, but in case others here don't visit there, the solution is to connect the antenna control from the radio to the vehicle's wiring harness - this triggers power for the antenna amp.
Thanks guys. Ok, so grech, I think what you are saying is correct, since the installer definitely told me that he put a different antenna in. What you and Rudeney are suggesting are two different things though, right?
Grech's solution would be to buy the adaptor on eBay which ties the unit into the stock in-glass antennas.
Rudeney's solution would be to keep the aftermarket antenna but use the built-in antenna amplifier (this may already be the way it's set up... I'm not sure).
Which is the better solution? Is the stock in-glass antenna pretty much the best way to receive AM/FM reception in a car? I would assume so, given the fact that it seems like kind of an elaborate strategy for Benz to use if it didn't provide advantages.
Thoughts?
Thoughts?
carlos uses this one:
http://www.crutchfield.com/p_12044UA...versal+antenna
Thoughts?
Thoughts?
MBworld Guru
Ok so Rudeney, your suggestion then is the same as grech's in that I should buy that dual aerial antenna adaptor on eBay in order to use the built-in antenna, correct?
Just trying to get a read on if the built-in antenna is a better option than something like the Crutchfield one mentioned in this thread. Sounds like you think it is.
MBworld Guru
Yes, get the adapter to plug the vehicle's antenna into your HU, then make sure you tie the HU's power antenna output to the antenna power pin on the vehicle's wiring harness.
I use a different unit. Helped a little, maybe about 20-30% but no where near OEM. WHen you get an AFM headunit, you typically loose on the AM/FM porion but gain all the other features. I've just been using different apps on my iPhone as a replacement.
I use a different unit. Helped a little, maybe about 20-30% but no where near OEM. When you get an AFM head unit, you typically loose on the AM/FM potion but gain all the other features. I've just been using different apps on my iPhone as a replacement.
1. The wiring harness from the back of the radio, (A5) is 12V switched when the radio is turned on.
2. Pin Legend, note (A5) is 12V switched when the radio is on.
3. If you don't want to enable it through the radio harness, you can tap your antenna 12V switch via the black cable going into the antenna amplifier, located on the driver side C pillar.
4. The wire diagram for the connector for picture 3 (X1/22), the antenna amplifier is A2/71.
Are you keeping the factory amp just for convenience? I looked at mine (it's still in there) and it's tiny. Even a $99 aftermarket amp would provide much better sound.
https://mbworld.org/forums/clk-class...o-install.html
FYI, I bought the double Fakra antenna that grech suggested in order to use the in-glass stock antenna and it works quite a bit worse than an aftermarket antenna. If you don't have a way to use another antenna, go for it, but for anyone reading this thread in the future, I would consider it a last resort.
I know there is a wire in the adapter that is supposed to be powered up for the adapter to work properly. Perhaps you could try that?
Btw I ordered the single adapter that I posted earlier in the thread, and installed my head unit last week with the antenna adapter. The FM radio reception is as good, if not slightly better (prolly the excitement of the new HU
I will be adding HD radio to my current setup (in 2-3 weeks) so I thought I would try to enable the factory amp. Nobody has provided pin/harness info on this, so I looked at my W209 shop DVD and found the wires and harnesses I think would do the trick (for my 2004 CLK500 Coupe). I will be updating this thread and my Radio thread with my results. Now the pics:
Success! Today I removed the aftermarket antenna and reconnected the factory antenna. After testing the radio and verifying that reception was terrible, I tapped into the black wire on the c-pillar and BOOM! Crystal clear radio reception using the factory powered radio antenna!
Success! Today I removed the aftermarket antenna and reconnected the factory antenna. After testing the radio and verifying that reception was terrible, I tapped into the black wire on the c-pillar and BOOM! Crystal clear radio reception using the factory powered radio antenna!![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
thx
MBworld Guru
The pillar letter nomenclature starts at the front. The A pillar is the support on the side of the front windshield. The B pilllar is the one behind the driver's door (between the doors on a sedan)), but since the CLK is a "pillarless" coupe, there is no B-pillar. The C pillar is the on along side the rear glass. And if this were an SUV or wagon, the C-pillar would be behind the rear door, and the D pillar would be alongside the rear hatch.
thx m8, appreciate it
will tap black wire in the weekend
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
