Car stalls when put into reverse..
Old Jan 12, 2012 | 01:16 AM
clk1014's Avatar
2006 clk500
So this is a fairly new problem, during the cold months i usually let my car warm up for about 5 minutes before putting it in gear, even after letting it warm up it still begins to shake and then stalls when put into reverse....!!? Took it to a local indy and he said it was the electronic throttle accelerator motor or something along those lines. Has anyone experienced this problem?
Old Jan 12, 2012 | 09:05 AM
Glyn M Ruck's Avatar
Super Moderator
He could mean that the Throttle Body actuator is defective & not properly respondng to the ECU. The engine should not stall when loaded in open loop mixture enrichment.
EDIT: Please scan for stored codes & post.
