Severe noise from engine
Old Mar 6, 2012 | 05:38 PM
joedirty's Avatar
CLK 500 w209
hi all, hope you can shed some light on my problem. I have a clk 500 w209 and every time i start it , it makes a loud wyning noise from front of motor, very loud to start with then gets quieter but always there.
The noise does get louder with high rpm.
Doesnt change pitch with steering wheel movement but i am still thinking power steering pump.
Hope this is a good description.
Last edited by joedirty; Mar 7, 2012 at 06:36 AM. Reason: changed does to doesnt change pitch
Old Mar 6, 2012 | 07:01 PM
kbahl21's Avatar
CLK & GL
Does chage pitch with steering wheel movement but i am still thing power steering pump.
belt?
Old Mar 6, 2012 | 07:41 PM
Schmitty63's Avatar
2005 CLK 500 cabriolet
yah, sounds like a belt to me too.
Old Mar 6, 2012 | 10:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
A common failure is the belt tensioning pulley and/or the idler pulley. I'd remove the belt, then check them by rotating them by hand. If they feel rough at all, then replace them.
Old Mar 6, 2012 | 11:48 PM
joedirty's Avatar
CLK 500 w209
Thanks, will inspect further and keep you posted
Old Mar 7, 2012 | 01:21 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Also check the power steering fluid. My C class did exactly the same thing, the fluid was very low.
Old Mar 7, 2012 | 05:59 AM
Glyn M Ruck's Avatar
Super Moderator
I hope it does not sound like this or you have a Torque converter/input shaft bearing/transmission oil pump failure.
Old Mar 7, 2012 | 06:12 AM
joedirty's Avatar
CLK 500 w209
definetly not that loud/rough. that sounds expensive Glyn
Old Mar 7, 2012 | 06:27 AM
Super Moderator
Phew! I'm pleased for you. We have had a whole rash of these lately with people who do not service their transmission every 39K.
Then yours is likely just an idler or tensioner pulley.
