command 2.0 to 2.5
Old May 10, 2012 | 11:40 AM
Bi66s's Avatar
03 CLK500
command 2.0 to 2.5
hi guys i have a 03 clk500 with command 2.0 i was at the junk yard and seen they had a clk500 with command 2.5 can i swap this with the a/c controls and all the feature buttons at top the command is $75 feel like i can work everything else in for another $75 total $150 the volume button on my command 2.0 is worn out and is about $50 on ebay i feel his would be better investment
Old May 10, 2012 | 10:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's possible, but there are a lot of complications because of some of the CAN bus and fiber changes with the facelift. I know some guys over on the benzworld W203 forum did this, but it ended up being expensive.
Old May 10, 2012 | 11:49 PM
ZEEK's Avatar
Yo Momma
Dude, where is that car at which junkyard? I need some parts. Will you pm me and let me know? Thanks
Old May 27, 2012 | 05:50 PM
omega48er's Avatar
2009 clk-350 (Black) AMG, 2009 clk-550 (Pewter) AMG
^ same here. i need A PILLARS to do a custom audio install. thank you =]
Old May 28, 2012 | 03:14 AM
Peydidy's Avatar
C63 AMG
I know of a few guys on the w203 section who did this, theres even a DIY about it, the w203s and w209s share a very similar set up so you could use that to help you along the way. I even tried doing it on my dads coupe once and I can tell you from personal experience that it is going to be expensive and very difficult.
