Make the ride less harsh
Old May 10, 2012 | 04:57 PM
king11's Avatar
clk350
I want to replace the original tires on an 08 clk 350 convertible with four equal size 245/50R. I think the bigger aspect ratio, (higher side wall) will significantly improve the ride quality. I don't think wheelwell clearance is a problem. The original tires are 245/40R
The local MB dealer advises against doing it but primarily I think because its not the way the car was equipped originally.
I'd appreciate any thought on this.
Old May 10, 2012 | 06:25 PM
Glyn M Ruck's Avatar
Super Moderator
You would have to recalibrate your speedo with Star but higher profile will make the car more comfortable as will selecting a tyre like the Michelin PS2
What wheel set up & offset are you running? A 245 will usually touch the front strut with 235 being the largest front tyre you can run with standard offset.
Old May 11, 2012 | 08:29 AM
king11's Avatar
clk350
You're right. I have 225/45 F & 245/40 R. Maybe 235/50 all around?
Old May 11, 2012 | 08:43 AM
Super Moderator
235 all round will work but look slightly skinny on the rear. I'm still contemplating de-staggering mine & running rear wheels up front as well. I've decided if I do this to run 235 front & 255 rear on identical rims all round. Yes I know this means I can only rotate across the same axle. I just think it will look good & I can live with the increased scrub radius up front.
Old May 12, 2012 | 04:04 PM
king11's Avatar
clk350
If I do 235's all around can I use the wheels I have now?
Old May 12, 2012 | 06:49 PM
Super Moderator
Yes if you have the standard wheels on the car.
