- Mercedes-Benz C-Class: Why is there Burning smell Coming out of My Car?
Guide to diagnose trouble and recommended solutions
Browse all: Engine Diagnostics
Smells like something burning
This most often happens after brake pads are replaced, though.
Perhaps after a few miles the high spots on the rotor are enough to push the caliper back in ??? Just a guess.
Common sources of smells on M112/722.6 combo.
- Power steering banjo joint leak at rack getting fluid on exhaust or flexible pipe leak.
- Captive engine breather covers on camboxes leaking oil onto exhaust.
- Transmission Electrohydraulic pilot bush leaking fluid onto exhaust.
- Transmission cooler line Banjo joints leaking fluid onto the exhaust.
- Exhaust shield detached somewhere exposing underbody sealant.
- Fitment of any new exhaust component.
- Tyres touching fender linings.
Good luck!
One day my dash alternator light came on, a replacement alternator was installed, and the smell vanished! It turns out, the bearing was over heating and the burning smell made its way into the cabin.
Hope this helps someone on the same hunt I went through.
Curiosity
I have an oil leak on what appears to be a valve cover. It is a small cover on top right side of the engine. It is a small leak that has been going into the exhaust manifold.
I guess I need a new gasket
I've had the valve cover gaskets replaced twice and still get a few small drips of oil seeping out and dripping onto the exhaust heat shield, now only on the left side. Happens within the first several miles of starting the car, then it either stops or maybe another drop. I can tell when it happens if the wind is right and I'm stopped at a light...the smell gets sucked into the cabin air intake. It's an unusual smell, so I heated up a piece of metal and put a drop of Mobil 1 on it...that's the smell. Also, when I get home I pop the hood and check with a flashlight and sometimes I see a little wet spot on the heat shield.
My indy mechanic says he occasionally sees warped valve covers (not as many as on BMWs). He installs the gaskets dry. I asked about using a gasket compound but he doesn't like to do that... says he's seen issues with it. The guy is meticulous.
So, I get an occasional whiff of it, and someday I'll have him check it again. I don't do work like that myself because I am a klutz.
I get an awful something burning kind of smell, but pretty much only when I drive up a hill.
I replaced the filters, and there are no indications of any kind of leak.
It is my impression that is on the passenger side, and other than an impending alternator bearing failure I am pretty much at a loss on this one...
my naive guess would be where the exhaust pipe bolts up and I can try tightening the collar
