Gap specs on clk
Old Jun 4, 2012 | 02:04 PM
Johninboston's Avatar
2006 clk 500 coupe
Gap specs on clk
I recently bough a 2006 clk500 coupe . Im in the process of rebuilding it . I have an new front end . Can anyone tell me if mercedes has gap specs available to install the front hood , fenders and bumper to factory condition ? Thanks for any help you could give me .
Old Jun 5, 2012 | 11:32 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here you go:
W209 Hood Gaps Specification
FYI, the coupe is 209.3, cabriolet 209.4.
Old Jun 6, 2012 | 04:58 AM
2006 clk 500 coupe
Thank you very much Rodney .
Old Jun 6, 2012 | 09:43 PM
bheng's Avatar
2003 CLK 320
and how do you perform the adjustments if i may ask.
Old Jun 6, 2012 | 11:12 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
@bheng: It depends. If you are replacing one panel, say a fender, then you install it, leaving the bolts slightly loose, the adjust it to match the hood and bumper. If you are installing an entire front end, then you actually start with the hood, then the fenders, then the bumper, checking gaps at each step. As long as the "frame" is straight, it's fairly easy to align everything as you go. Use a plastic wedge as your measurement tool.
Old Jun 6, 2012 | 11:19 PM
bheng's Avatar
2003 CLK 320
ahh ic.
i was thinking about realigning my hood. seems a bit off and was always wondering if there was a way to adjust
