service "B"
Old Jun 11, 2012 | 01:57 PM
midnight AMG's Avatar
CLK 550
service "B"
Service B ...
$249 Service B
plus $150 for brake fluid change
thought that was a pretty decent deal...
thoughts?
Old Jun 11, 2012 | 02:30 PM
billyhead1's Avatar
CLK 320
249 for a B service is a pretty good deal. they should do: oil change, air filter, cabin filter (the one above the battery). optional/less frequent would be the activated charcoal filter under the dash (just changed that one myself and it is a pita)
Old Jun 11, 2012 | 06:59 PM
CLK 550
yah i know $249 is the absolute bare minimum price..
usually its $220 for the brake fluid change so I got a good deal..
I've had my CLK 2009 for 3 years now so I'm over due for brake fluid by virtue of time (every 2 years you are supposed to change)
Old Jun 11, 2012 | 08:16 PM
bheng's Avatar
2003 CLK 320
i did my brake fluid last year. pita to do myself but bought a power bleeder helped a **** ton.
Old Jun 11, 2012 | 11:28 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I used a MityVac hand pump bleeder on my brakes. I think I paid $30 or so for it. It takes a while to do the job this way, but my garage time is free
Old Jun 12, 2012 | 03:08 AM
Peydidy's Avatar
C63 AMG
Hm $30s sounds like a pretty good deal to me, I think I am going to look into getting one too. Around how much time does it take to bleed all the brakes with the hand pump?
Old Jun 12, 2012 | 11:47 AM
RX729's Avatar
W203 W210 SW20 FC3S TBSS
is there a diy by any chance...?
Old Jun 12, 2012 | 10:34 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It took me about 10 minutes per wheel - lots of pumping! The CLK550's brakes don't like the fluid sucked out. When I got to the driver's front wheel, I reached in and pressed the pedal and it was at least 10x faster than using the pump.
Here's the bleeder I bought:
MityVac Bleed Kit
EDIT: Oh, and I highly recommend using colored fluid. If your current fluid is OEM (gold) colored, use ATE Super Blue. Then, when changing the blue, use the Type 200 Amber - it's all the same stuff, just different colors to tell when it's changed. Oh, and it exceeds MBZ specs.
Old Jun 13, 2012 | 01:47 PM
Peydidy's Avatar
C63 AMG
Thanks! I think I am going to order one, appreciate it
