Brake wear message
The brake sensors are designed to be replaced not reset. basically, the sensor is designed so that when the metal wire in the sensor comes into contact with the rotor face, the brake wear circuit is then completed. thus, the system trips the light or (as in your case) shows a message on the info display.
and the brake warning was still coming up
it ended up the rear sensor had failed when i removed the pads
the test is with a multimeter on ohms setting and the sensor should read 000 over the 2 plug in pins
as i didnt have a spare sensor i cut the sensor part off stripped the wires back and soldered them together and that completed the circuit until i get a new one Regards Pete
