CLK W209 Centre console upgrade
Old Dec 9, 2013 | 03:43 PM
thusi444's Avatar
clk
Hi Guys,
I have bought a facelift headunit for my car clk 2004 model.
But im having a problem to get it fit to my car as they are different connectors on the back of the headunit.
can you please help me with this to get the facelift headunit fit to my car.
I have attached some pictures on here to show you the different.
Also attached a picture of the connector which i found on ebay but not sure if this works.
Thank you
http://www.ebay.co.uk/itm/MERCEDES-B...item3a6e63a150
Attached Thumbnails CLK W209 Centre console upgrade-clk-a10.jpg   CLK W209 Centre console upgrade-facelift-head-unit.jpg   CLK W209 Centre console upgrade-connector.jpg   CLK W209 Centre console upgrade-facelift.jpg
Old Dec 9, 2013 | 04:30 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
Originally Posted by thusi444
Hi Guys,
Thank you
You might wanna do a search. There is significantly more work involved than that. So, you're trying to do a facelift upgrade basically. What did your car come with initially?
Old Dec 9, 2013 | 04:39 PM
thusi444's Avatar
clk
I have got pre- facelift centre console
Old Dec 9, 2013 | 04:51 PM
megacrazy's Avatar
Check this link out. It'll give you a pretty good idea what's involved.
http://mwstewart.co.uk/articles/w209faceliftconsole/
Old Dec 10, 2013 | 03:17 AM
thusi444's Avatar
clk
I have seen this link but not really sure what to do as the back connectors are different
Old Dec 10, 2013 | 09:06 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'm really not sure about those rear connectors. I am pretty sure the main two 8-pin connectors are the same on both units, but the wiring harness connection looks different. I know in the USA, the connector did not change for the facelift (they all look just like the one on the back of the COMAND unit in your second photo), but I have no knowledge of UK models - maybe there was a difference there?
Old Dec 28, 2013 | 02:16 AM
M-Rods's Avatar
2013 C350 Previous: 2004 CLK 500, 2001 CLK 430
In the link you posted from the Uk site the pic of the entire dash dismantled actually made me feel actual fear!!!!!
Old Dec 28, 2013 | 04:19 AM
thusi444's Avatar
clk
I know it looks bit scary but it wasn't a bad job.
Old Dec 28, 2013 | 01:26 PM
megacrazy's Avatar
So you completed it?
Old Dec 28, 2013 | 01:33 PM
thusi444's Avatar
clk
Yeah all done . Everthing works. Please visit uk forum I have uploaded all the pictures. Still steering control button dont work with the new facelift audio 20. But I can live with that as the centre console look lot newer compare to my old pre-facrlift look.
Old Dec 28, 2013 | 01:37 PM
thusi444's Avatar
clk
http://forums.mercedesclub.org.uk/sh...=126147&page=3
Old Jan 4, 2014 | 10:57 PM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
i hope this helps
https://mbworld.org/forums/c-class-w...will-melt.html
Old Jan 5, 2014 | 12:04 PM
OverDrive's Avatar
Volvo
Originally Posted by sweet jones
I need to fix those pictures on my DIY, I plan to redo it sometime soon. I also plan to do with my CLK, which I bought all the pieces expect for the Command System it self.
To take away from this post one of the harder pieces to get or find is the Dash/Radio Plastic Frame. Took me a couple try's at the dealership before they got me the correct piece. You remove the old frame before you can even mount the new radio, buttons and A/C controls.
Old Feb 11, 2016 | 04:41 AM
PornoKing's Avatar
CLK A209
Upper control panel issue
Dear Gents
I've done center console upgrade recently on my w209 04my clk 320 Europe and I have UCP problem. Parktronic off button is working one way, meaning when you press it you've got red led on and parktronics switched off, pressing again-no response, parktronics doesn't turn back on. ESP button on this facelifted UCP works normally. Any comment on how to fix it would be helpful.
Old Mar 20, 2017 | 06:59 PM
iBan Barrado's Avatar
Clk w209 270cdi
Originally Posted by PornoKing
Dear Gents
Hi,
I have the same problem. Anyone can help me?
Thanks!
Old Mar 21, 2017 | 02:20 AM
PornoKing's Avatar
CLK A209
You need to swap pts unit (parktronik control unit) which is under passenger floor to facelifted version. I used this one: A2035454932. Now all is fully functional
Originally Posted by iBan Barrado
Hi,
Thanks!
Old Mar 21, 2017 | 05:39 AM
Clk w209 270cdi
PornoKing,
Thank you so much!! TOP!!
I have the rear blind and the same problem, do you know the part number of the facelifted version of rear blind control unit?
Old Mar 21, 2017 | 08:20 AM
PornoKing's Avatar
CLK A209
Unfortunately can't advice on blind cause my car is cabrio and I don't have it, but I think it should be fixed the way you thinking
PornoKing,
