need a light
Old Jul 25, 2012 | 08:43 PM
djscottyboy2000's Avatar
mercedes benz c clk 500
need a light
Hello and good evening, i had an accident with my car, it is a 2004 mercedes benz clk 500 and the car lighter is not working, can anyone tell me where the fuse would be for the lighter
Old Jul 25, 2012 | 09:51 PM
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
Fuse # is 47 Engine compartment
Old Jul 29, 2012 | 08:13 PM
fuses
Hey Louie, thank u for the information, i have one more question for u, what color fuse would it be, i have never seen so many fuses in my life for one car, it's crazy, lol, Oh, one more thing, is it one fuse or two different fuses
Old Jul 29, 2012 | 10:17 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This is a 15 amp fuse, so it will be blue. Here's a diagram that will help you locate fuse #47:
Front SAM Fuse Assignment
Old Aug 1, 2012 | 05:42 PM
Hey Rudeney thank for the diagram, it is now working real good, i have another question, i have a sun shade that comes up inside the car and it will not come down, is there a way to get it down, i don't mind the shade but i would like to see out of my back window if u know what i mean, lol!!!!!!!!!!!!!!
Old Aug 1, 2012 | 08:58 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There is probably trash in the arms. You'll need two people - one to press the switch, the other to gently press the arms to the center so they will start moving again.
Old Aug 15, 2012 | 07:18 PM
Hey Rudeney, u r pretty good, that worked as well, let me ask u one more question, the windshield wipers will not stay on and everytime i push the button it never stays on, talk to me broman, let me know what i need to do, i appreciate it
Old Aug 15, 2012 | 09:36 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Go, guru, go!
Old Aug 15, 2012 | 10:29 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just to make sure, are you twisting the wiper control knob to set it to rain sensor/slow/high or pushing it in for a single swipe/wash?
Old Aug 16, 2012 | 09:32 PM
when we turned the knob for the wipers to go on, the wipers do not move and i don't know why, what can u tell me broman
Old Aug 17, 2012 | 10:04 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
First, check fuse #46 (the fuse box under the hood). If that's not it, does the washer work? If not, then you probably have a bad wiper/turn signal switch assembly. One thing you might try is to see if you can turn on the wipers with the turn signal on (left or right). If that works, then it's definitely a bad switch.
Old Aug 19, 2012 | 08:15 PM
Hey Rodeney, it is the switch, what can i do to get it replaced, i replaced the fuse and it was not it, it is definitely the switch
Old Aug 19, 2012 | 11:00 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The part itself is around $100. You have to take the steering wheel, airbag, and "clock spring assembly" out to get to it. It's not crazy-difficult, but you have to be careful.
Old Aug 21, 2012 | 10:00 PM
Ok cool, could u send me a diagram like u did before, i will go get the piece that i need, oh by the way, what piece to i need and how long will it take for me to put it in
Old Aug 21, 2012 | 11:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here are the WIS docs, in order:
Airbag
Steering Wheel
Steering Column Module (a.k.a. Clockspring Module)
Steering Angle Sensor
Steering Wheel Adjuster
Cruise Control Switch
Steering Column Combination Switch (<- that's the part you need)
Old Aug 22, 2012 | 05:45 PM
Hey Rodney, I appreciate it my man, good looking out, i will be takeing care of it this weekend, if something else comes up, i will make sure i hit u broman, again thanks for the information and graphs
Old Oct 8, 2012 | 04:49 PM
Hey Rodeney, how r u my friend, it has been a while, i want to thank u for the info u sent to me for the signal piece, it is not working perfectly, i now am having a problem with the filters, i am thinking that there are three filters that go in the car, could u help to let me know which ones are n the car, the car started sputtering like it wanted to cut off and i am thinking that it may be the filters, what can u do for me my friend
Old Oct 8, 2012 | 10:04 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You mean the engine intake air filters? There are two - inside the main plastic engine cover.
Old Oct 18, 2012 | 07:57 PM
ok cool, can I do the job as far as changing them myself, what do i need to do broman, because money is scarce right now, just trying to get by if u know what I mean, lol!!!!! Oh one more thing, are there any sensors on the filters, I was told that they are sensors, I do no belive it
Old Oct 18, 2012 | 09:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There are no sensors on the air filters. Just remove the plastic engine cover, flip it over and you'll see some TORX screws to remove. The filters are under there.
Old Oct 18, 2012 | 10:23 PM
do I need a special screw driver to get if off or can I use a regular screw driver, could send me a picture so I can take a look my friend
Old Oct 19, 2012 | 10:18 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You need a TORX driver. There are different sizes - I don't recall which size you need, maybe a 15 or 20? If you are going to do any work at all on the car, get yourself a set. THey look like this:
