CLK Lower grill Help.
C63 507 AMG DA Car #19
I have a 2004 CLK55 AMG which I actually installed the later year 2007 3 slat grill with no problem, so I suspect you should be able to go the other way.
The 3 slat grill requires a different top plastic mount than the 4 slat AMG grill.
You can get all the parts on parts dot com.
GL.
GL.
MBworld Guru
The factory part won't fit, but you could fabricate something from aftermarket cross-hatch grille material. I bought a sheet of it to fabricate mesh to cover the old round fog light opening when I went with the L-shaped LED light bar DRLs.
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
If you do attempt it, take some photos and do a DIY. I've wanted to remove my lower grille forever, so I can wrap it in body-color vinyl and change out my foglight bulbs, but I KNOW I'll break clips without a DIY....
