fitting new wheels
Old Sep 2, 2012 | 11:16 PM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
fitting new wheels
hey guys i just got cls 63amg wheels which, which are 5 spoke 19 inch
the wheels rub against the strut. I was wondering if there is a way to make the wheels fit? Or will these not work without changing the suspension?
Attached Thumbnails fitting new wheels-t2ec16zhjf0e9nmfsue7bqqmooqwww-60_57.jpg
Old Sep 2, 2012 | 11:26 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Spacers. They must be hub centric. Some have had good luck, other serious vibrations after installing.
Old Sep 3, 2012 | 12:09 AM
fusion2007's Avatar
thanks, any size recommendation?
Old Sep 3, 2012 | 03:25 AM
fusion2007's Avatar
im running into a height issue, the black part of the strut hits the top of the tire..
how can i solve that?
Old Sep 3, 2012 | 05:35 PM
EuroTra$H's Avatar
19 C300
The wheels are the wrong offset... You need to get wheels that fit properly or you will have constant ride quality issues
Old Sep 3, 2012 | 06:07 PM
fusion2007's Avatar
oh ok. when u say ride quality do you mean just rougher? is there anyway to make these wheels fit?
Old Sep 3, 2012 | 08:37 PM
Mka77's Avatar
It sounds like the double edged sword. Wrong offsets and tire sizes. What size are the front tires? Anything over a 235/35 is going to be extremely close.
I believe the CLS with 19's run a 255 front, and 285 rear which neither size is suitable for a CLK. Your best bet is to go another route unfortunately.
Old Sep 3, 2012 | 09:21 PM
fusion2007's Avatar
yup your right
fronts 255/35/19
rear 285/30/19
is there any way to make it work? i think back will fit
Old Sep 3, 2012 | 09:42 PM
M-bENZ's Avatar
Corrolla
Change your front tire ?
Old Sep 3, 2012 | 09:55 PM
fusion2007's Avatar
would that that work? is that all? would i have to change the height of the tires? like 255/25 or 20
that wouldnt messup the front/rear ratio?
Old Sep 3, 2012 | 10:03 PM
fusion2007's Avatar
would that that work? is that all? would i have to change the height of the tires? like 255/30 or 25
Old Sep 4, 2012 | 01:50 AM
ahmadk's Avatar
2011 E550 Sedan
you should go with 235/30 in the front
Old Sep 4, 2012 | 10:50 AM
Mka77's Avatar
A 235/35 up front. No spacers if offset is correct. I haven't seen anywhere on these boards that a 285 rear will work.
A 275 with custom made wheels and perfect offsets has been proven to work without issue.
Old Sep 4, 2012 | 02:20 PM
fusion2007's Avatar
alrite thanx. im gonna try and find some cheaper/smaller tires to put on these wheels then
it sucks cuz the tires on them now are like new
Old Sep 4, 2012 | 04:50 PM
Mka77's Avatar
Just make sure you think everything through before just going out and popping for new tires.
Confirm the wheel offsets will in fact work on the CLK front and rear. I know for a fact that a 235/35/19 on an 8.5 wheel with and et32 is within a couple mm's of rubbing the front strut tube, not to be confused with what you experienced with the spring perch.
A 265 rear is the preferred size. And offsets anywhere from 40-25 will work safely on a 9.5" wheel. Good luck with it.
Old Sep 4, 2012 | 05:18 PM
M-bENZ's Avatar
Corrolla
If I'm not mistaken ur front has 28ET and Rear is 25 ... Check it right behind your wheels.
Old Sep 4, 2012 | 07:45 PM
EuroTra$H's Avatar
19 C300
Square peg... Meet round hole.
I don't mean to burst your bubble, but those wheels will never be right for the car.
Your best bet would be to sell that setup and get a set of wheels that properly fit your car. You are driving a MB...
When I said ride quality issues... I mean you will have to run way to much spacer.. You will run into balancing issues.To make the set up work you are going to have to run very odd tire sizes not reccomended for the car.
Of all the mods you must get right, wheel tire combo is most important... It is going to drive youCRAZY and cost a small fortune to keep tweaking the set up to force it to work.
You have a chance to do it right the 1st time.... why fight it
Good luck!
Old Sep 4, 2012 | 09:45 PM
Mka77's Avatar
Well said Euro. I have tried to explain it as thoroughly as possible. I even forgot to ask about proper lug bolts lengths and what not.
fusion, its really not worth the trouble you are going through. Just trying to help. Take no offense.
Old Sep 4, 2012 | 11:50 PM
fusion2007's Avatar
i know, no offense taken. you guys are much smarter then me about all this, so ill take your word for it, im puting these wheels on ebay tommrow.
Old Sep 5, 2012 | 12:07 AM
M-bENZ's Avatar
Corrolla
i know, no offense taken. you guys are much smarter then me about all this, so ill take your word for it, im puting these Wheels on eBay tomorrow.
I think you already did lol. There is a set of wheels ( like your picture ) is bidding on eBay right now ,
http://www.ebay.com/itm/300772483399...9#ht_500wt_922
Old Sep 5, 2012 | 12:25 AM
togaclk55's Avatar
CLK55
GLWS
Old Sep 5, 2012 | 09:38 AM
fusion2007's Avatar
haha, actually thats where i "borrowed" the picture from, theres not enough light in my garage to take pics... i post my link to auction as soon as post it this afternoon.
thanks for wishing me luck.
these new wheels are heavier then the stock amy wheels, and will probably slow me down some.lol
would 235-40-18 be fine for fronts?
or 235-35-18? is the only option?
lol sry this was my last retarted question
Old Sep 5, 2012 | 09:55 AM
fusion2007's Avatar
some last maybe helpful pics
Attached Thumbnails fitting new wheels-2012-03-16-08.49.34.jpg   fitting new wheels-2012-03-16-08.49.47.jpg
