Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old Jun 18, 2013 | 12:09 PM
  #226
Markcsons's Avatar
2006 c280
Originally Posted by Markcsons
Rodney,
Got the codes and had cam magnet sensors changed but issue still there. Can you check VIN #WDBRF92H36F780142.
Thank you
Rodney - took 2006 C280 to dealer after getting shaft codes and told it is balance shaft, total repair cost $5,300 with Mercedes covering $500. Car has 108K miles so no warranty. Hard to believe my first (and probably last MB) has this defect with so little care by MB. Any thoughts on further action with MB or whether to repair?
Old Jun 18, 2013 | 05:30 PM
  #227
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Two years ago, they were quoting $4K, now it's up to over $5K? Wow! Sorry, the only way to fix this is to pull the engine and replace the balance shaft. Did you contact MBUSA for help, or did you just work with the dealer? I would contact MBUSA - go to the website and send them an email. Be nice, and beg for help. You may get it. If not, then I'd try an indy to see what they would charge. It won't be cheap, but it will be less than dealer prices. Otherwise, you have to decide - drive it 'til it dies or sell it (I'd trade it at a non-MBZ dealer - they may just assume the MIL is something simple).
Old Jun 18, 2013 | 06:30 PM
  #228
Markcsons's Avatar
2006 c280
Yea, $5480 to be exact...dealer offered $500 off. I contacted MBUSA and supposed to hear from them tomorrow. Also called my local mechanic who said he could do it and is coming up with price - will definitely be cheaper than $5k. MB dealer also said he heard "growling" from transfer case...guess I got a lemon. I'm trying to "be nice" but its hard! Thanks for the reply...Mark
Old Jun 19, 2013 | 11:23 AM
  #229
Paulers's Avatar
CLK550
another vin check
Please Rodney
WDBTK72F87F221790
Paul
Old Jun 19, 2013 | 11:18 PM
  #230
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK72F87F221790 has M273 engine #119881, which is beyond the range for balance shaft problems.
Old Jun 22, 2013 | 09:48 AM
  #231
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Some interesting videos showing the balance shaft failure issue:
http://www.benzworld.org/forums/w203...ml#post5834366
Old Jun 23, 2013 | 11:07 AM
  #232
todderobert's Avatar
2006 CLK 350
Wife's 2006 CLK350, just purchased
Hi Rodney, and you are definitely a very knowledgeable individual!
I just purchased a 2006 CLK350 for my wife and would ask if you could tell me if my VIN is in the range. WDBTJ56JX6F191051
Old Jun 23, 2013 | 11:37 AM
  #233
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTJ56JX6F191051 has M272 engine #289800, which unfortunately is in the range for a potentially defective balance shaft. Did you get a warranty? If not, and you can get one at a good price, you might consider it. Remember, just because it's in range doesn't mean it will fail, just that there is a chance.
Old Jun 23, 2013 | 12:33 PM
  #234
2006 CLK 350
Bought the extended warranty, AMEN
Rodney, I was concerned enough that I purchased the extended warranty that covers all internally lubricated engine parts, harmonic balancer, all timinig components. So from reading your many posts, you suggest I go to a MB dealer and have them pull the error codes log from the onboard computer to see if the error code 16 or 17 was ever displayed?
Also, would the MB dealer have a record of having replaced this in their system?
Old Jun 23, 2013 | 02:38 PM
  #235
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If the balance shaft was replaced, it would likely have been done at a dealer, and there would be a record of it. Also, you don't have to go to the dealer to check codes - you can get an inexpensive generic OBDII reader for $40+/- that will do. It won't read any advanced systems (transmission, ABS, SRS, etc.) but it will show the ECU codes, so look for P0016 and P0017.
Old Jun 23, 2013 | 06:17 PM
  #236
2006 CLK 350
Codes to read
Okay, thanks for your assistance, I will report back in a couple of weeks when I have the car, the codes and the knowledge, I hope.
Old Jun 28, 2013 | 09:31 PM
  #237
cdumitru's Avatar
2005 E55, 2014 370Z, 2004 Mini Cooper JWC
could someone please check on this vin for me, we test drove am ML350, and might want to buy it... 4JGBB86E77A271366
Thank you in advance
Old Jun 28, 2013 | 11:50 PM
  #238
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
4JGBB86E77A271366 has M272 engine #629682 - that one is outside the problem range.
Old Jun 29, 2013 | 12:16 AM
  #239
cdumitru's Avatar
Oh man, thanks for the good news. I don't even own the car yet but I feel better about it. I will go through the forum and learn more about it, I was always a BMW/Lexus guy but once my wife saw the ML's we really started to like them quite a lot.
Old Jun 30, 2013 | 03:03 PM
  #240
clarksports's Avatar
e350
Could you please tell me if I am inside the problem range WDBUF56X17B011460
Old Jun 30, 2013 | 08:58 PM
  #241
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBUF56X17B011460 is MY2007 E350 with M272 engine #426675, which is within the affected range for potential balance shaft failure.
Old Jul 3, 2013 | 06:21 PM
  #242
jivko2886's Avatar
Mercedes CLS350
Hi Rudeney,
Could you please check the following VIN for me:
WDD2193561A030747
Thanks!
Old Jul 3, 2013 | 10:45 PM
  #243
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDD2193561A030747 has M272 engine #86672. That is within the range for potential balance shaft problems.
Old Jul 4, 2013 | 01:31 AM
  #244
jivko2886's Avatar
Mercedes CLS350
Thanks Rodney.
My only hope is that this has been replaced before I bought the car although there's no such replacement in the service book.
Old Jul 4, 2013 | 10:19 AM
  #245
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That is possible, but also, it is possible it will never fail, or won't fail until very high mileage. The belief is that not all balance shafts in the range will fail, probably because only a small percentage were manufactured incorrectly. Since MBZ could not tell which ones were bad, the TSB includes all 550,000 engines built during the time prior t when the manufacturing problem was discovered and corrected.
Old Jul 5, 2013 | 11:57 AM
  #246
mrmarie's Avatar
C-CLass w204
Is my w204 2013 in the range for problems?
VIN: WDD2040311A791347
ENGINE NO: 27491030024076
Thanks Rudeney
Old Jul 5, 2013 | 12:50 PM
  #247
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, your 1.6l M274 engine will not have balance shaft troubles. That problem only affected the M272 V6 and M273 V8 engines. Basically, no W204 C-Class should ever experience the balance shaft failure because even the C300 and C350 in that chassis were built years after the problem was corrected.
Old Jul 5, 2013 | 01:44 PM
  #248
mrmarie's Avatar
C-CLass w204
w204
Thank you Rudeney
Old Jul 10, 2013 | 02:26 AM
  #249
static706's Avatar
2006 CLK350
Hi Rudeney can you please check my vin#WDBTJ56H76F189478?
To see if I'm affected
Thank you
Old Jul 10, 2013 | 10:16 AM
  #250
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTJ56H76F189478 has M272 engine #273237, which is in the range for potential balance shaft problems.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
