Please check my VIN for Balance shaft issue?
Old Jan 8, 2014 | 08:16 PM
  #451
adamjeeps's Avatar
Maybe R350
Can someone check this VIN for me, may be purchasing it:
4JGCB65E67A055616
Thank you in advance.
Adam
Old Jan 9, 2014 | 07:18 PM
  #452
cgx0820's Avatar
CLK350
Would someone check the engine number for this vin?
WDBTK56F97F225782
Thank you very much
Cynthia
Old Jan 9, 2014 | 08:21 PM
  #453
dariusf's Avatar
2023 CLA 250, 2021 GLC43, 2003 CLK320
My CLK320 is 2003 so should be outside of this but we also have 2011 E350 which I hope is not effected as it looks like 2010 was the last effected year.
VIN
WDDHF8HB0BA316314
Thanks!
The car manufacture date is September 2010.... but it is 2011 model.... Hope I'm ok
Old Jan 9, 2014 | 08:36 PM
  #454
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Adam: 4JGCB65E67A055616 has M272 engine #570061 and that is beyond the affected range for balance shaft failure.
Cynthia: WDBTK56F97F225782 has M272 engine #595205, and it is also beyond the affected range.
Darius: My EPC doesn't have your E-class in it (my copy is a few years old and only goes through MY201), but I can tell you that by MY2008, the balance shaft issues were resolved, so your MY2011 will have no problems with that.
Old Jan 9, 2014 | 08:54 PM
  #455
dariusf's Avatar
You are awesome, thanks for your help! Greatly appreciated.
If not too much trouble can you also check my 2003 CLK320?
VIN WDBTJ65J13F012446
It will let me sleep at night, I already had the $7k repair with the radiator leak to trans issue. Had to get new trans, radiator and deferential.... so hope not another large issue....
Old Jan 9, 2014 | 09:32 PM
  #456
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
CLK320's are fine, too. That has the M112 engine and it's as solid as a rock - no worries. It was only the M272 and M273 engines with balance shaft problems. The M272 was introduced int he MY2005 SLK350 and then went fleet-wide in MY2006 with the 230 (V6), 280, 300, and 350 models. The M273 is the V8 version of the engine and it's found in the 450 and 550 models. Basically, any M272 or M273 through MY2006 will be affected,a nd about half of the MY2007s. They discovered the problem and revised the part before any MY2008's were manufactured, although I did see one case where a MY2008 had an affected engine, but it was a foreign market model, and it's possible that it was actually a MY2007 sold as a MY2008.
Old Jan 9, 2014 | 09:56 PM
  #457
adamjeeps's Avatar
Maybe R350
Thanks Rodney, much appreciated.
Old Jan 11, 2014 | 01:31 AM
  #458
Haris sheikh's Avatar
Mercedes CLK280 A209
WDB2094542T082131
I'm getting error codes p0016 and p2004 I have changed the magnets but not the sensors. Can sumone plz help me....
Thank you very much
Haris
Old Jan 11, 2014 | 02:18 AM
  #459
Peter S's Avatar
2000 clk 320
Please help me my Vin# WDBTJ56J86F192537
Thank you
Old Jan 11, 2014 | 12:44 PM
  #460
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDB2094542T082131
Thank you very much
Haris
Haris, you have M272 engine #542695, which is beyond the range for balance shaft issues, but still in range for camshaft solenoid (a.k.a. magnet) failure. Did you replace all four? If so, the P0016 may be something else - it could be a bad camshaft adjuster or a problem with the timing chain. P2004 is a problem with the tumble flaps in the intake manifold, which is totally unrelated to all of this.
Old Jan 11, 2014 | 12:45 PM
  #461
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Thank you
You have M272 engine #300465, which as expected with a MY2006 is in the affected range.
Old Jan 11, 2014 | 12:59 PM
  #462
Peter S's Avatar
2000 clk 320
Thank you very much Rodney!!
Peter
Old Jan 12, 2014 | 01:39 AM
  #463
Smile Thank you soooo much Rudeney ure a life saver....
Hi there Rudeney yes I have changed all four magnets bought it from mercedes dealership and installed them my self which took me abt an hour. But I have not changed the camshaft sensors as there are really expensive last time I checked from the dealership they wore £150 each. Do you one of those sensors needs tobe changed?
Where and what is the camshaft adjuster? And are the timing belt quite expensive to change on m272 engine?
Above all I haven't lost any power from the engine the engine is still solid as rock and it still drives smooth it's just the engine management light really annoying.
Thank you sooooo much Rudeney once again....
Old Jan 12, 2014 | 06:39 PM
  #464
springe97's Avatar
CLK350
Can you please check the follow Vin: WDBTK56F37F212221 to see if it is in the range.
Thank you
Old Jan 12, 2014 | 08:58 PM
  #465
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK56F37F212221 has M272 engine #446715, which as expected with a MY2006, is in the range for potential balance shaft failure.
Old Jan 12, 2014 | 09:10 PM
  #466
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The position sensors could be bad, but I wouldn't replace them until you know they are faulty. Did you reset the errors? You need to do that to see what returns. My guess is the P0016 was caused by a bad solenoid and was fixed with their replacement. The MIL is likely on due to the intake manifold tumble flap problem.
Oh, and your car ha no timing belt - it's a timing chain and it should last pretty much for the life of the car.
Old Jan 14, 2014 | 03:53 PM
  #467
TruTaing's Avatar
Moderator Alumni
w203 m112
I believe I read this thing correctly and my dad's 2008 e350 is NOT affected by fault scenario 1 and 2, but could potentially be affected by fault scenario #3. Could someone verify what I found and correct me if im wrong?
WDBUF56X08B274881 and an engine number of 272964 30 822366
Thanks!
Old Jan 14, 2014 | 11:00 PM
  #468
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Correct - scenario #3 in the TSB covers M272 engines up to 895140.
Old Jan 16, 2014 | 12:59 PM
  #469
rrk's Avatar
rrk
CLS 350
Can you please check the follow Vin:WDD2193561A005319 is in the range, thanks in advance
Old Jan 16, 2014 | 05:03 PM
  #470
golf_234's Avatar
07 C230 6MT
Me as well please !
WDBRF52H07F849153
Old Jan 16, 2014 | 08:10 PM
  #471
golf_234's Avatar
07 C230 6MT
Bump
Old Jan 16, 2014 | 09:00 PM
  #472
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Your CLS350 has M272 engine #016335, which is within the range for potential balance shaft failure.
Old Jan 16, 2014 | 09:03 PM
  #473
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by golf_234
Bump
Patience please! Some of us have to work our day jobs!
Your C230 has M272 engine #416134, which is within the affected range for potential balance shaft failure.
Old Jan 17, 2014 | 05:45 AM
  #474
rrk's Avatar
rrk
CLS 350
Thank you
Old Jan 19, 2014 | 09:52 AM
  #475
CMW1077's Avatar
2007 Mercedes Benz c280
I am considering buying a 2007 Mercedes Benz c280 4matic - WDBRF92HX7F876643 - could someone check the VIN and let me know if I will experience potential balance shaft failure. Thank you
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
