Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old 07-19-2015, 12:19 AM
  #1151
MBworld Guru
Rudeney's Avatar
Received 1,002 Likes on 870 Posts
NO LONGER ACTIVE
Originally Posted by tasabbath
Can someone please check my vin and let me know if my car is in the affected range. I have. 2007 R Class 350
4JGCB65EX7A038981
you have M272 engine #416570, which is in the range for potential balance shaft failure.
Old 07-22-2015, 10:53 AM
  #1152
tasabbath's Avatar
2007 R350
If my vehicle is in the range for potential balance shaft failure and I currently have a Power Train Warranty will that cover to have it replaced?
Old 07-22-2015, 10:45 PM
  #1153
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
It depends on what your warranty covers, but it is an internal engine part. I feel certain that it will have to fail before they would pay to replace it. Just being "in the range" does not mean it "will" fail.
Old 07-23-2015, 12:22 AM
  #1154
hamooda_47's Avatar
2013 E300 AMG
Good day All,,
Can someone check this VIN# WDDHF5EB0DA730456
I've checked and shows 272952 32 078734, and it should be below 30 468993
if I consider the 32 then NOT in the range, without considering 32 then IN range.
Any clarification? Thanks in Advance
This is the website I used =>
http://www.vindecoderz.com/EN/Mercedes-Benz
Old 07-23-2015, 10:49 PM
  #1155
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
That's a MY2013 - no worries there! balance shaft problems ended halfway through MY2007. Yes, the "32" makes yours well beyond the range. I typically just post the last 6 digits of the engine serial number, but really, it's 8 digits.
Old 07-27-2015, 01:50 PM
  #1156
KushionT's Avatar
GLK350
C230 2007
can someone tell me if this model is affected? I'm looking to purchase this car for my wife today.
VIN : WDBRF52H07F909500
Engine part # : 272920 30 561707
I am thinking that "561707" is out of the range but can someone confirm?
Regards,
Pete
Old 07-27-2015, 11:04 PM
  #1157
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Hi Pete - welcome to MBWORLD! Yes, M272 engine #561707 is beyond the balance shaft problem range. The affected range ended at #468993.
Old 07-29-2015, 10:03 PM
  #1158
Gunararenberg's Avatar
2007 c230 sport
2007 c230 sport
Can i get a check on VIN: WDBRF52H47E026375.
Thank you! Dont want to purchase a problem with 80k miles for $9k
Old 07-30-2015, 08:20 AM
  #1159
vpipis's Avatar
2006 E350 4matic
hello all
I have a 2006 E350 with VIN WDBUF87J16X200235
is it within the affected range? I am getting a P0016 code intermittently, on or off for hours on either state. Usually off when car starts at least until engine fully hot. Observing the cams at 305 degrees of crank I see left cams centered, right intake centered, right exhaust off a bit. Any info or ideas appreciated
thank you
Old 07-30-2015, 11:48 PM
  #1160
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
That one has M272 #427633 which is in the range for potential balance shaft failure.
Old 07-30-2015, 11:49 PM
  #1161
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by vpipis
hello all
thank you
All MY2006 M272 engines are "in the range" for potential failure, and P0016 is a tell-tale symptom.
Old 07-31-2015, 11:48 AM
  #1162
andycbush's Avatar
C280
Rodney
I am looking at a 2007 C280 with 60k miles. The vin is WDBRF92HX7F912573.
Can you tell me if this engine is in the affected range?
Andy
Old 07-31-2015, 11:11 PM
  #1163
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by andycbush
Rodney
Andy
M272 engine #546412 - beyond the problem range.
Old 08-13-2015, 04:31 PM
  #1164
VK45's Avatar
CLK 500
2007 clk 350
WDB2094562T065076.
ENG27296030232332
Is this engine effected by balance shaft issues
Old 08-13-2015, 11:20 PM
  #1165
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, engine #30-232332 is in the range for potential balance shaft failure (it's through engine #30-468993)
Old 08-15-2015, 05:22 PM
  #1166
rlagm3's Avatar
my engine number is 272960 30 316188
am I affected by this?
Old 08-15-2015, 11:43 PM
  #1167
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, all M272's up to #468993 (full serial number is 272xxx 30 468993) will be in the range for potential balance shaft failure.
Old 08-17-2015, 02:02 AM
  #1168
jethal's Avatar
2007 C280 4matic
For those with impacted M272/273's, there was a settlement in the Northern California case.
Go here: https://eclaim.kccllc.net/caclaimforms/mse/home.aspx
then click on Claim Form Generation.
I wonder if a new thread has been made about this, or if a new thread should be placed in the car sections where this engine could be an issue?
Old 08-17-2015, 12:37 PM
  #1169
algemene's Avatar
2007 BMW 335i Convertible/ 2006 CLS 500
Could someone please check out this vin: WDBUF87X27X211637 07 e350
Thank you so much in advance.
Old 08-18-2015, 12:30 AM
  #1170
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
M272 engine #409254 - it is in the range for potential balance shaft failure.
Old 08-24-2015, 02:33 PM
  #1171
zebrowskis's Avatar
2007 Mercedes C230
2007 C230
Rudeney, could you check my VIN to see if I'm within the affected range please VIN# WDBRF52HX7E024890.
Thank you.
Old 08-25-2015, 12:04 AM
  #1172
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Thank you.
That one has M272 engine #402887, which is in the range for potential balance shaft failure.
Old 08-25-2015, 07:15 PM
  #1173
vpipis's Avatar
2006 E350 4matic
Rodney if I may bother you again, where can I find my engine number? Need to see if the balancing shaft sprocket was ever addressed by a dealer and I need my engine number for the class action settlement claim. VIN is WDBUF87J16X200235
thanks a million
Old 08-25-2015, 09:52 PM
  #1174
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
thanks a million
It is "272.972 30 251978"
Old 08-27-2015, 10:03 PM
  #1175
dpsierra's Avatar
2008 E350 4MATIC Wagon
Liked to know if my car is affected
Hi- Just bought a 2008 E350 Wagon, 70,000 miles. Vin is WDBUH87XX7X220824 I'd like to know if my car is affected. It doesn't seem like it had a balance shaft repair and I have an opp to get an extended warranty.
Thanks!!
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: Please check my VIN for Balance shaft issue?
