Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old Aug 1, 2016 | 06:40 PM
  #1301
coachz's Avatar
1993 sl500. And C-Class 280
coach z
Ciao. I have a 1993 sl500 and love to drive this car. Summer carI am looking to buy a 2007 mb c class 280 4matic
Can someone check my VIN and see if the balance shaft will be ok.
VIN WDBRF92H77F868774
Car has 77k miles and they want 11k for it. It is clean
Grazie. This is my first post so thanks for and help and I will be glad to share regarding my sl500. Ciao
Old Aug 1, 2016 | 10:53 PM
  #1302
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBRF92H77F868774 has M272 engine #468571, which is in the range for potential balance shaft failure. I will say that if you are in the USA, $11K is far too much for this car, regardless of potential balance shaft issues.
Old Aug 6, 2016 | 01:16 PM
  #1303
Turbotoll's Avatar
CLS 550
CLS 500 (550)
Could you check my VIN number as I can't get it to work on any of the sites?
It's a German delivered May 2007 car brought to the Netherlands in 2014, ±60000 miles so far.
WDD2193721A113183
Cheers!
Old Aug 6, 2016 | 09:46 PM
  #1304
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDD2193721A113183 has M273 #151738, which is beyond the balance shaft problem range.
Old Aug 7, 2016 | 01:41 PM
  #1305
coachz's Avatar
CoachZ
The mechanic checked the balance and said it was ok. The dealer paid 10k for the car. 2007 class 280 with 76k
Any other issues? What if I can get a warranty? Can I drive this a upstate ny winter?
Old Aug 7, 2016 | 02:57 PM
  #1306
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
4MATIC is great for winter driving. How did the mechanic check that balance shaft? There are three ways to check: pull codes, remove the camshaft position sensors and visually check the position of the machine marks on the camshaft adjusters, or actually look at the idler sprocket inside the timing case. The only sure way to know is to inspect the sprocket. The other two methods only tell you that is "has failed and must be replaced". Checking the sprocket itself you can tell if it has worn or is still in factory-cast condition. I have heard of some people using a boroscope to check the sprocket, but I am not sure you can actually see enough of it to tell for sure. Personally, I'd look for a less expensive open that is not in the balance shaft failure range.
Old Aug 13, 2016 | 08:23 AM
  #1307
coachz's Avatar
CoachZ
How to repair armrest pocket on door of 1993 mb sl500 the screws and metal plate that hold it to the panel are missing. Thanks
Old Aug 13, 2016 | 08:53 AM
  #1308
ALFAitalia's Avatar
Alfa 159
I think you have posted in the wrong place...this is the forum for 209 models and this is a thread about balance shaft issues! Lol.
Old Aug 15, 2016 | 10:27 AM
  #1309
bd5024's Avatar
Mercedes Benz C230
Please Check my Vin
I have a 2007 C230.
Vin# WDBRF52HX7E026168
Old Aug 15, 2016 | 10:16 PM
  #1310
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBRF52HX7E026168 has M272 engine #437793, which is in the range for potential failure.
Old Aug 29, 2016 | 07:09 PM
  #1311
farmingtonflyer's Avatar
2006 e350
I have a 2006 E350
S/N WDBUH87JX6X209686
Old Aug 29, 2016 | 10:53 PM
  #1312
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
All MY2006 xx350's will be "in the range" for potential balance shaft failure.
Old Sep 1, 2016 | 01:51 AM
  #1313
rlnzler's Avatar
2015 C300 and 2007 C230
Hi, here is my vin: WDBRF52HX7A946213 it is an 07 C230. I had the code P0022 come up tonight and wondering if this is that issue.
Old Sep 1, 2016 | 09:50 PM
  #1314
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBRF52HX7A946213 has M272 engine #506079 which is beyond the balance shaft problem range, but it's still in the range for bad camshaft adjuster solenoids (see scenario 2 in the TSB linked below). P0022 = DTC 0276, which is a symptom of that. There are four - one for each camshaft. They sell for about $25 each at discounted parts sellers and are a fairly easy DIY.
http://benzbits.com/BalanceShaftTSB.pdf
Old Sep 9, 2016 | 08:00 AM
  #1315
jjday's Avatar
2005 clk320
Hello,
Does this vin have the balance shaft issue?
WDBTK56F28F242893 2008 clk350
Old Sep 9, 2016 | 09:17 PM
  #1316
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, it was fixed before MY2008 production.
Old Sep 13, 2016 | 07:24 PM
  #1317
GregMb320's Avatar
1997 E320 sedan
2006 E350 4matic
can you please check my VIN #
WDBUF87J46X206692
fingers crossed !!!! Thank you
Old Sep 13, 2016 | 09:37 PM
  #1318
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MY2006 with an M272 engine? Yes, they are ALL in the range for potential balance shaft failure.
Old Sep 14, 2016 | 09:54 AM
  #1319
GregMb320's Avatar
1997 E320 sedan
Thank you sooo much !! Just bought the car this weekend and codes poped up P0016 & P0017 , car runs smooth and normal like nothing wrong with it , what next ? Replace the sensors or go to dealer and let them do their job ?
Old Sep 14, 2016 | 11:05 PM
  #1320
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
P0016/P0017 are symptoms of balance shaft failure. Sensor replacement will not fix this. The engine must be pulled and the balance shaft replaced. Prices will range from $4K-$6K to have this done.
Did you buy from an MBZ dealer? If so, I'd DEMAND that they either take the car back or fix it for you at no cost. They should have scanned codes and these would have been stored long before the MIL illuminated. If you bought it elsewhere, I'd stills ee if they will help. Was there any warranty?
Old Sep 15, 2016 | 05:58 AM
  #1321
GregMb320's Avatar
1997 E320 sedan
It was non MB dealer , local small car dealer , they got me some 24 months warranty but when got to the dealer MB yeaterday i was told it doesnt cover the damage and 8500$ quote for repair!!! I dont know why cus my wrranty is for engine , tranny and all 4 matic components .....dealer said my warranty its just basic thats why .... So i asked if i upgrade my warranty for every single best coverage he said it is too late ??? Dont understand .....
i just started this thread yesterday
E350 P0016 & P0017 codes and im broke
Old Sep 15, 2016 | 10:43 AM
  #1322
Paulers's Avatar
CLK550
Small Dealer
Tell that small dealer to refund your money and put that car back in the auction. Maybe you will buy a different car from him
Old Sep 15, 2016 | 08:21 PM
  #1323
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Don't take the MBZ dealer's word that your warranty does not cover this - they are notorious for just dismissing aftermarket warranties because it may be some extra work for them to deal with. I'd read the warranty and see what it says it covers and contact them directly to find a service center they will recommend.
Or, as Paulers said, go back to the seller and see if you can get any relief.
Old Sep 21, 2016 | 07:13 PM
  #1324
dedalos99's Avatar
CLS-55 AMG
2012 R-350
Rodney
Can you please check my VIN number if failing to Balance shat category.
2012 R-350
Vin 4JGCB5HE4CA138042
Thank you so much
Old Sep 21, 2016 | 09:54 PM
  #1325
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No worries on a 2012 - this problem was corrected halfway during MY2007 production.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
