Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old 10-24-2017, 12:07 AM
  #1451
lakef's Avatar
2007 E350
Originally Posted by Rudeney
Assuming you are in the USA, I've found https://www.genuinemercedesparts.com/ has good prices.
Keep in mind that your error code is related tot he CRNAKSHAFT position sensor, and there's only one. the Camshaft position sensors rarely fail. I'd clear the code and see if it comes back before spending the money on it.
Ok that's what I thought. You Have helped a lot. If you don't mind , I also have intake manifold runner stuch open control bakk 1. I have seen many replacement parts for this fix made of metal. Do you have any recommendations on witch one to buy?
Old 10-24-2017, 08:20 AM
  #1452
Keith Slarke's Avatar
SLK 230
VIN number check for balance problem
A check for the balance problem would be appreciated this car is in the UK
VIN WDB2094562T102835
Thank you
keith
Old 10-25-2017, 12:50 AM
  #1453
MBworld Guru
Rudeney's Avatar
Received 1,004 Likes on 872 Posts
NO LONGER ACTIVE
Thank you
keith
That's a M72 #31-049717 - way beyond the problem range.
Old 10-25-2017, 12:54 AM
  #1454
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
My advice on intake manifold issues is to replace the entire housing. Don't take chances with cheap repairs because internal part can break away and get sucked into the cylinder and cause catastrophic engine damage. You can buy the OEM (Pierburg) for a reasonable price.
The following 3 users liked this post by Rudeney:
ecmexchange (11-10-2017), Keith Slarke (10-25-2017), lakef (10-25-2017)
Old 10-25-2017, 05:02 AM
  #1455
SLK 230
Thank you very much
Keith
Old 10-25-2017, 07:06 PM
  #1456
lakef's Avatar
2007 E350
Ok I thought from my research tha most of the time it was the plastic arm that broke b/c of a bad design. I will take it apart when I replace the magnets and inspect. Along with more research.
Old 10-25-2017, 10:53 PM
  #1457
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Sometimes there is a plastic lever on the manifold that breaks, but sometimes it breaks because an internal tumbler breaks and locks up.
Old 10-31-2017, 08:19 AM
  #1458
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Can someone please check this one for me. I sold my other car yesterday so i need to get a new one ASAP. WDBUF56X87B135855 thanks in advance
Old 10-31-2017, 09:28 PM
  #1459
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
M272 engine #607423 - beyond the balance shaft problem range.
insame1 (11-01-2017)
Old 11-01-2017, 07:58 AM
  #1460
insame1's Avatar
Thanks for you help! Unfortunately i went to see this car yesterday and it is junk. My quest continues.
Old 12-22-2017, 05:32 PM
  #1461
JustClk's Avatar
Clk kompressor
Engine number please check.
27294040421079. ( engine number)
hi hi all please could you check this engine number, considering buying a CLK 280 sport (2006) and need to know if this is in the affected range... also, if so what are the chances off it being unaffected? Any way of knowing
Old 12-22-2017, 05:56 PM
  #1462
JustClk's Avatar
Clk kompressor
Question Safe engine number?
27294030421079
above is clk 280 sport 3 litre 2006,
is is this within the safe range?
Old 12-22-2017, 10:37 PM
  #1463
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
That engine is in the range for potential balance shaft failure.
JustClk (12-23-2017)
Old 12-28-2017, 04:11 PM
  #1464
spaulhus's Avatar
12 E350 Cabrio & 19 C300
Can you please check my VIN? WDBTK56F78F235843
Thanks in advance
Old 12-28-2017, 09:38 PM
  #1465
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBTK56F78F235843 has M272 #675235 - it's beyond the balance shaft problem range.
spaulhus (12-29-2017)
Old 01-07-2018, 10:15 AM
  #1466
BFerNJ's Avatar
07 slk350
Rudeney,
New guy here. I am considering buying a 2007 SLK350. VIN
WDBWK56F27F142188
Is this one of the balance shaft issue cars?
Thanks much
Old 01-08-2018, 07:51 PM
  #1467
gasoel's Avatar
2012 E350 - P2, 08 E350 AMG Sport, . 96 E300D 230+k. 03 Limited 4xSequoia & 2011 Volvo C30 R design
Greetings and Happy New Year – Would you mind checking another VIN please? WDBUF56X18B272718 - 08 E350
Hoping I’m OK as I just spent over $5,200 on the timing chain tensioner and all cam adjuster issue for my 2012 E350. MBUSA and Dealer took care of 40% of the 8K job. Bought and serviced at same dealer for the life of the car. Just out of extended warranty by miles 90K. Took a lot of fighting just to get them to pay part. Thanks a ton,
Old 01-09-2018, 10:31 PM
  #1468
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by BFerNJ
Rudeney,
WDBWK56F27F142188
Thanks much
M272 engine #438754 - it's in the range for potential balance shaft failure.
Old 01-09-2018, 10:32 PM
  #1469
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
MY2008 is beyond the balance shaft problem range.
Old 01-10-2018, 01:47 PM
  #1470
Kelvin Bellrose's Avatar
2007 CLK550 Coupe, 2003 CL600, 2012
Can you check mine too?? Thanks.
Since you are on a roll, my vin is: WDBTJ72J07F230961
I checked on my own and it looked like it was not in the range, but a second opinion would be great.
Thanks.
Kevin.
Old 01-10-2018, 03:36 PM
  #1471
Can you Please check mine too?
Can somebody delete this???
Old 01-10-2018, 06:33 PM
  #1472
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Thanks.
Kevin.
M273 engine #146246 it is beyond the "balance shaft" problem range.
Kelvin Bellrose (01-10-2018)
Old 01-12-2018, 01:56 AM
  #1473
gasoel's Avatar
Thanks a ton Rudeney for checking all of these.
Old 01-22-2018, 03:52 PM
  #1474
hudge's Avatar
clk280
Balance Shaft Issue
WDB2094651T003038 This car is in Spain, going to see it later this week, one owner, full history. Balance shaft issue?
2003 CLK320 60.000 miles
Old 01-23-2018, 11:03 PM
  #1475
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
No worries about a CLK320 - its M112 engine has no balance shaft troubles.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: Please check my VIN for Balance shaft issue?
