Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old 04-17-2018, 12:56 AM
  #1501
Billy550's Avatar
CLK-550
Vin Check please,
I would like to know if my engine is within the threshold of balance shaft issue. My Vin# .WDBTJ72H67F207424 thank you very much for your time..
Old 04-17-2018, 12:59 AM
  #1502
xsever's Avatar
2012 C300 4MATIC Sport
Your engine's serial number is 273967 30 055486 so yes it is in the threshold since M273 Engine up to Serial No. 2739..30 088611 is affected.
Old 04-17-2018, 01:13 AM
  #1503
Billy550's Avatar
CLK-550
so what's the symptoms of the problem if there is any? No engine light ever. 98k, could it if been fixed already by recall? Is there any way to find out?
Old 04-17-2018, 01:24 AM
  #1504
xsever's Avatar
Read through this thread and you will find all the information you need and more.
Old 04-17-2018, 08:32 AM
  #1505
Kahin Dur's Avatar
CLK550
CLK550 VIN balance check
Hello all,
Thank you for helping me with my issues in a previous thread. I also would like to know if my 2009 CLK550 is within the affected range as it was build in Aug 2008, I believe.
My VIN is WDBTK72F09T101308
Thank you once again.
Old 04-17-2018, 10:02 AM
  #1506
xsever's Avatar
Originally Posted by Kahin Dur
Hello all,
2008 cars are all beyond the range so not affected. It's only 2006 and up until mid 2007 models that are affected. By August 2008, the CLK had all its problems sorted out. 05, 08, or 09 CLKs are the best option.
Kahin Dur (04-19-2018)
Old 04-17-2018, 08:53 PM
  #1507
DM914's Avatar
none currently
CLK550 - 2007
I have Vin # WDBTK72F97T080603 - a 2007 cabriolet only has 72,000 KM but wonder if the engine is one thats effected by the potential deceive balance shaft... no codes so far...
Old 04-18-2018, 12:06 AM
  #1508
xsever's Avatar
Your engine's serial number is 273967 30 099200 so no it is not in the threshold since only M273 Engine up to Serial No. 2739..30 088611 is affected.
DM914 (04-18-2018)
Old 04-20-2018, 10:49 AM
  #1509
mthomson's Avatar
2005 CLK320
Could you please check VIN WDBTK56F07T078544? I just purchased this 2007 CLK350 and am hoping I'm good.
Thank you,
mark
Old 04-20-2018, 04:46 PM
  #1510
xsever's Avatar
Thank you,
mark
Your engine's serial number is 467994 so yes it is within the range of affected engines.
Old 04-21-2018, 09:05 AM
  #1511
mthomson's Avatar
2005 CLK320
Thank you for checking. I was afraid that might be the case so now it looks like I have a lot of reading to do.
Old 04-21-2018, 11:16 AM
  #1512
Rob Vail's Avatar
2007 CLK550 Coupe
Looking to buy a 2007 CLK550. I checked the Russian site and it listed the car as a CLK500 and the engine number as 104177 (if correct, I believe just out of range), but I'm not sure I trust the info is correct.
Would someone be nice enough to double-check this VIN? WDBTJ72H47F218275
Old 04-21-2018, 11:24 PM
  #1513
MBworld Guru
Rudeney's Avatar
Received 1,004 Likes on 872 Posts
NO LONGER ACTIVE
No need to use the "Russian" site - this one works easily and in English:
https://www.datamb.com/
Yes, that one has 273 engine #104177 which is beyond the timing chain idler sprocket problem range.
Old 04-22-2018, 09:42 AM
  #1514
Rob Vail's Avatar
2007 CLK550 Coupe
Thanks Rudeney! Cheers!
Old 05-07-2018, 09:54 PM
  #1515
Pauliescff's Avatar
C230k
WDBRF52H36A864659
can someone run this vin for the balance shaft please?
2006 c230
thank you
Old 05-07-2018, 11:25 PM
  #1516
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by Pauliescff
WDBRF52H36A864659
2006 c230
thank you
It's a MY2006 - yes, it is in the range. Only M2007 needs to be checked for engine serial number.
Old 05-22-2018, 06:30 PM
  #1517
autojava's Avatar
C280 2006
This VIN is in the range? WDBRF54H56A845785
Hi, Rudyney:
2006 C280 V6 M272: report P0019, P0304, P0305, P0306, and P0300.
Old 05-22-2018, 10:28 PM
  #1518
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Being a MY2006, the engine is in the range for potential balance shaft failure, but none of those codes are that. The P030x codes are "misfires". P0300 = "general misfiring" and the others indicate the cylinder numbers (4, 5 and 6). The OBDII code P0019 can represent four different MBZ-specific DTCs. They are all dealing with the left-bank timing:
1201 Constant adjustment of exhaust camshaft of left cylinder bank in direction 'Advanced' (P0019)
1202 Constant adjustment of exhaust camshaft of left cylinder bank in direction 'Retarded' (P0019)
1203 Constant adjustment of exhaust camshaft of left cylinder bank in direction 'Advanced' (P0019)
1204 Constant adjustment of exhaust camshaft of left cylinder bank in direction 'Retarded' (P0019)
It is possible that you have a cam adjuster issue that is causing the misfires. Unfortunately, none of these are easy fixes and are going to require a qualified mechanic to inspect things for a proper diagnosis. One thing I will mention is that I had this code on my CLK550 and it was due to a racked flywheel (damaged by the dealer when repairing the "balance shaft").
autojava (05-31-2018)
Old 05-25-2018, 02:38 AM
  #1519
Smalbi Incheto's Avatar
W211 E350
Mercedes w211 E350
please check my WIN number Is there a problem with the balancing shaft
WIN WDB2110871X181077
Old 05-25-2018, 05:01 AM
  #1520
W211 E350
Mercedes w211 E350
my Mercedes spends oil What might be the reason
Old 05-25-2018, 09:03 PM
  #1521
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
M272 engine #038891 - yes, it is in the range for potential balance shaft failure.
Old 05-28-2018, 05:05 AM
  #1522
topgun129's Avatar
06 C350 4Matic
hi, can you please check this vin # - WDBUF87X87X219032. thank you.
Old 05-28-2018, 05:15 AM
  #1523
xsever's Avatar
Engine serial number is 272972 30 463849 so yes it is within the affected range.
Old 05-31-2018, 05:38 PM
  #1524
autojava's Avatar
C280 2006
Thanks. Rudeney. It turns out to be the issue of camshaft Adjuster. MB dealer charge $2900 to fix the issue. plus $220 diagose cost and TAX, it costs me $3100 in California.
Old 06-19-2018, 03:45 AM
  #1525
Stoimen Stoev's Avatar
cl 500
Cl500
WDD2163711A014302
Can you please check this vin?
Thank you!
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: Please check my VIN for Balance shaft issue?
