Clk 350 problem
Old Sep 23, 2012 | 04:11 PM
Saracar's Avatar
Clk350
Clk 350 problem
Has anyone had the faulty timing chain gear? I have a v6 clk 350 with 78000klms , the engine light has come on intermittently and each time I took it to dealer was fobbed off as no problem found - maybe it spark plugs fuel etc. I believe the problem is the faulty part known to Mercedes
Old Sep 23, 2012 | 04:19 PM
iyeoh's Avatar
CLS550
What year is this vehicle?
Old Sep 23, 2012 | 04:28 PM
Saracar's Avatar
Clk350
2006,
Old Sep 23, 2012 | 05:54 PM
iyeoh's Avatar
CLS550
It is a known issue with 2006 vehicles. The dealer ought to know what is going on. There is a recall. Look at the forum stickies. In fact, there are class actions on 2006 models.
Old Sep 23, 2012 | 06:49 PM
Saracar's Avatar
Clk350
350
thanks for that- yes i have found by googling there is an issue with the part - one article states mercedes will fix it but i very much doubt this
it sure has put me off ever considering another mercedes as i have always had bmw's before this car
how do i find stickies
thanks
Old Sep 23, 2012 | 07:33 PM
iyeoh's Avatar
CLS550
Inside this forum, close to the top, you will find a thread called "M272 Engines"... Read that. I know that you didn't realize, but it's unfortunate that you ended up with a 2006 model 350.
Old Sep 23, 2012 | 07:51 PM
Saracar's Avatar
Clk350
thanks will do probably not much i can do beside sell the car and return to a 3 series
Old Sep 23, 2012 | 08:11 PM
Yidney's Avatar
2008 CLK550 Cab
Try getting a goodwill repair from Mercedes even though you are out of warranty. Be nice but persistent.
Old Sep 23, 2012 | 09:35 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Find out what the error codes are. The balance shaft/timing gear problem will present DTCs 1200 and 1208 (corresponding to OBDII codes P0017 and P0016). If that's what you have, then you have the balance shaft failure. If not, then it's not related to the balance shaft.
