Diagnostic Trouble Error Code P2442
Old Sep 23, 2012 | 10:11 PM
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
My wife came home today said the check engine light was on, hooked it up to me reader 2 codes where showing the 1st was P2442 and the 2nd it said was pendind what ever that means. Looking it up I came up with Secondary Air Injection System Switching Valve Stuck Open. I have been getting a strange smell from somthing from time to time if that means anything, though maybe the cats where going out.
Is there a DIY on this or is this something I need to bring the car in..
Old Sep 23, 2012 | 10:39 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That error is DTC 0821: "The secondary air valve (cylinder bank 2) is jammed open." Bank 2 is the left (US drivers side) of the engine. The valves are under the front engine cover, right behind the air pump. I assume the bank 2 valve would be on the left side of the engine (on your right, standing in front of the engine looking at the air pump).
Old Sep 23, 2012 | 10:52 PM
Louie D's Avatar
Any clue what it looks like ?
Old Sep 24, 2012 | 03:50 PM
Louie D's Avatar
Rodney,
Are you talking about the EGR Valve ? See attached
Old Sep 24, 2012 | 09:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, look at the air pump. Standing in front of the engine, you'll see one large hose exiting the pump on the top right, and another on the bottom left. Follow those, and you'll find on each hose a silver "mushroom" valve. The left side valve (to your right when standing in front of the engine) is right behind the oil filter. The right side valve is below and to your left of the air pump. Sorry, I'm too lazy tonight to take a photo, but I found this one. This is an M272, but it's the same on the M273. The air pump is in the red circle, and you'll see the valve:
Old Sep 24, 2012 | 09:40 PM
Louie D's Avatar
Ok these I take it...Those are the ones I listed in the pic I posted..
Parts #
0021407560 Right
0021407460 Left
http://www.parts.com/parts/2007/MERC...%2Doff%20valve
The top one looks hard to get off..
Attached Thumbnails Diagnostic Trouble Error Code P2442-engine_17_modified.jpg
Old Sep 24, 2012 | 11:02 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yep, but before you buy one, maybe you should check it out and see if a vacuum hose or electrical connector is loose. Or, take it off and see if it has some trash in it. The air pump intake comes "downstream" of the air filters, but it could still have trash in it if the intake hose was ever disconnected (it's easy to forget to reconnect it when removing the top engine cover).
Old Sep 24, 2012 | 11:06 PM
Louie D's Avatar
Took it off cleared the codes with it off and no Check engine or new codes is it possible to clean it out ?
Attached Thumbnails Diagnostic Trouble Error Code P2442-100_6385.jpg   Diagnostic Trouble Error Code P2442-100_6386.jpg
Old Sep 25, 2012 | 09:10 PM
Louie D's Avatar
Thanks Rodney all fixed. I sprayed WD40 in it bunch of black carbon build up came out. I then soaked it in alcohol all night blew it out with some air in the morning let it sit all day. Installed it when I got home from work all seems good no check engine light no codes, will take it for a good drive tomorrow.
This was a very DUI easy removal and install only one part needs to be removed to get to the valve.Took me 30 min to get it apart and about 5 min to put it back togther and another 20min to get all the freaking tools I dropped down on the car pan at the bottom. I was lucky to not have to replace the part.
OT a tad got a call from my SA he is a family friend said that here was a recall on the camshaft solenoid magnets, you mentioned to me in a PM. Well anyways he said bring it in and they will replace it. Thanks again for you help..
Old Sep 25, 2012 | 10:48 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That's got to be the best typo I've seen all week! The laugh is more than enough thanks, man! I'm glad I could help!
Old Sep 25, 2012 | 10:50 PM
Louie D's Avatar
Just noticed LOL might as well leave it..
Old Sep 25, 2012 | 11:27 PM
M-bENZ's Avatar
Corrolla
i wonder if u just bring the car to the dealer and see how much they charge for all that fix ... good job Louie
Old Sep 25, 2012 | 11:51 PM
Louie D's Avatar
Well I am pretty sure they would want to replace the part at 210.00 then 2 hours of labor so my guess would be high 300.00 to low 400.00 range.
Old Sep 29, 2022 | 06:27 PM
Solodolo91's Avatar
2011 c300 w204 luxury
Hey this code just came up on my 2011 w204 c300 luxury . I replaced the thermostat a few weeks ago & it turned out fine but a few days ago a check engine light came on for a code P0410 Secondary Air Injection System & under it says P2442 : secondary air injection system switching valve stuck open bank 2 .
Any help ? Please
