LED Interior Swap - CLK 200K
Old Oct 9, 2012 | 06:13 AM
jasmart's Avatar
CLS 450 4MATIC
Can anyone assist with the answer for below, I believe the dome front/map lights are "269 Festoon 11 x 30 mm Bulbs", not sure for the door courtesy, vanity mirror and glovebox lights though?
Originally Posted by AZN Optics
It looks like your interior is made of a series of festoon bulbs, but I don't have specs as to what size festoon bulbs. If you can pull out the bulb and measure it tip to tip, I can get you the correct bulbs for your application. We carry 31mm, 36mm, 38mm, 39mm, and 41mm so should have you covered.
Originally Posted by jasmart
Hi mate,
The posts here make an interesting read for the research and testing you've put into getting the right LEDs.
I'm interested in swapping out my interior, its a 2003 CLK 20K C209. What would the part numbers be?
thanks in advance
Jason
Old Oct 9, 2012 | 09:08 PM
Clkboi's Avatar
CLS550 4Matic
This should help.
https://mbworld.org/forums/clk-class...ed-change.html
Old Oct 9, 2012 | 09:12 PM
Clkboi's Avatar
CLS550 4Matic
Glove box uses the same as the rear dome light. Any size would fit really.
Door courtesy you have to use these:
You can get them here or cheaper on eBay: http://store.ijdmtoy.com/6-SMD-T10-L...t10-sku297.htm
I would suggest you go with these though if you want them super bright
You can buy them here: http://www.ebay.com/itm/LED-Courtesy...aa1aa0&vxp=mtr
Old Oct 10, 2012 | 01:58 AM
jasmart's Avatar
CLS 450 4MATIC
Originally Posted by Clkboi
Great post mate, thanks for the pointers
Old Oct 10, 2012 | 02:23 PM
Clkboi's Avatar
CLS550 4Matic
anytime
