What's the "best" navigation uint for a CLK500 2004?
Old 01-24-2013, 12:11 PM
ricardovasco's Avatar
CLK 500
I think you are correct. The EU units got the TV function:
http://www.ebay.de/itm/Mercedes-C-CL...item3cce273f13
http://www.ebay.co.uk/itm/MERCEDES-W...21116672339%26
http://www.ebay.com/itm/Mercedes-C-W...item4ac05e0caf
The US versions don't :
http://www.ebay.com/itm/2002-2003-ME...item4ac09d65e1
http://www.ebay.com/itm/Mercedes-Ben...71142658137%26
My car is EU version. Do you guys think I can only instal the EU nav unit or the US should work as well?
Old 01-25-2013, 12:18 AM
MBworld Guru
Rudeney's Avatar
Received 1,003 Likes on 871 Posts
NO LONGER ACTIVE
Non-USA COMAND units (i.e. Euro units) had a TV function. You could actually add an optional OTA TV tuner. USA models do not have this as it is not legal here. As for plug and play, COMAND is usually a direct drop-in for standard audio BUT you need to make sure if you have the Bose options, you get COMAND with Bose. And you may have to add a GPS for NAV to work.
Old 01-25-2013, 05:59 AM
CLK 500
Thanks Rudeney! My system is the Bose one. What comand should I get to be plug & play?
Old 01-25-2013, 09:50 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I think they all have the audio out via D2B, which should work with the Bose amp, but I understand the actual Bose versions of the radio have some special coding. Honestly, I would not go with an OEM COMAND unit - I'd rip out the Bose speakers and amp, run analog wiring from the dash to the trunk, and go with a good aftermarket system with a trunk-mounted amp.
Old 01-25-2013, 10:29 AM
CLK 500
Thanks Rudney. Most of aftermarket seller said that I don't need to replace the Bose speakers. Only the Bose amp .
Old 01-25-2013, 09:09 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The Bose speakers are 2ohms, and some head units won't drive them. Even so, the Bose speakers are not very good at producing full range sound - they rely heavily on special equalization in the factory head unit and the amplifier to sound decent.
Quick Reply: What's the "best" navigation uint for a CLK500 2004?
