HELP! TRANSMISSION ISSUES...
Also, did your mechanic say what was leaking? If two places told you your tranny is gone, then it doesn't look good. As for whether the seller knew, who knows. It's possible, but if it drove fine until now then maybe not.
When I replaced my ATF a few months ago, I suspected that there was some ATF leaked through the pilot bushing (13-pin connector). I did not see the leak but the surrounding area in the bottom engine cover was "moist".
Unfortunately, it's not easy to measure the ATF level.
I can't offer much advice on the matter but I wish you the best and try to stay positive in this holiday season. Good luck
10k miles later, car drives like new. Ask what codes came up and start with the conductor plate first before replacing the TCU too and ultimately the whole tranny.
Glycol contamination happened around 32K and conductor plate issues were around 70K. I'm at 83K now and the transmission still running smooth
