Stiff When Turning Right
Old Jan 2, 2013 | 03:39 PM
Newjd2's Avatar
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
First off Happy New Year to everyone!...
As a lot of you have followed my tough road with my car and the flood I'm glad to say the car has been home and the new engine is running fantastic! Definitely been amazing to have the car back.........until a problem just popped up...
Only when turning right the steering wheel gets stiff to turn. Can definitely still make the right turn, but it is definitely stiffer than turning it left. Any ideas? Checked power steering fluid levels and it all looks good.
As a note I did get my steering angle sensor replaced by the dealership so don't know if that or the clock spring inside have anything to do with it...also did the 5x turning the wheel thing...
Thanks for any help as always!
Angelo
Old Jan 2, 2013 | 06:04 PM
Glyn M Ruck's Avatar
Super Moderator
Is there any Aeration noise from the steering? I'm worried they did not bleed the system properly when they did the engine swap.
Old Jan 2, 2013 | 06:14 PM
Newjd2's Avatar
Aeration noise (like hissing?) when turning the wheel or just at a stand still?...because the only time I'll hear a hiss from the wheels is when I turn it ALL the way right or left at a complete stand still not when turning and moving...
Weird that it's only stiff turning right though. Could a bushing or control arm cause the same problem?
Angelo
Old Jan 2, 2013 | 09:29 PM
Super Moderator
Hissing or squealing at full lock is usually due to entrained air in the fluid as it passes through the pressure release valve.
It is extremely unlikely that this is a suspension issue. A seized/tight ball joint or strut tower bearing would fight in both directions. It's likely either that the PS system requires bleeding or you have a rack problem.
For it to be related to suspension or alignment something would have to be very wrong.
Old Jan 2, 2013 | 09:37 PM
Newjd2's Avatar
Hmmm...so bringing it back to the shop it is...I'll bring it in on Monday. Thing that gets me is that it's only on the right side...
If it was a rack problem wouldn't it affect my alignment? That got done when I had it at the shop during my engine swap and steering angle sensor swap.
Angelo
