Tire alignment
Old Feb 4, 2013 | 01:20 AM
ahmadnt's Avatar
E55 AMG 2003
Tire alignment
Hi, after changing both Camber and Caster bushes I’ve done acomplete tire alignment, attached the alignment report which looks fine to me, appreciateif you can review and confirm the same.
Old Feb 4, 2013 | 01:47 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Hmmmm.....why did you changed your camber and caster bushes? If you look at the before specs. You don't have any issues that related to the parts you replaced. The only issues with your alignment print out was the toe being out, which is very normal even under normal driving.
Old Feb 4, 2013 | 05:14 AM
ahmadnt's Avatar
E55 AMG 2003
Sorry I supposed to clarify this point, the boshes were in avery bad condition and I checked them myself and the alignment report done afterword so the report doesn’t show the specs before the bushes change.
In the attached report “Before” numbers shows the specs directly after the bushes change and the “Actual” numbers shows the final specs after the alignment completion.
