CLK-500 RennTech Airbox
Old Feb 22, 2013 | 06:05 PM
CLK-M113's Avatar
W207 E-400 Coupe
hello, can one see then the RennTech air box somewhere from the inside? Does a picture have, perhaps, one of it? What does the box bring in more power? Greetings from Germany, Udo
Old Feb 22, 2013 | 06:47 PM
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
Attachment 253758
By allowing a greater volume of intake charge air; Renntech carbon airbox upgrade allows for greater horsepower and torque across the entire RPM range. The result is an additional 10 HP and 10 Lb/ft with increased throttle response and improved drivability.
Old Feb 22, 2013 | 06:55 PM
CLK-M113's Avatar
W207 E-400 Coupe
hello, thanks. I think that she is a little higher like the standard box, or? Can one not change the series box also something? Greetings Udo
Old Feb 22, 2013 | 06:56 PM
Attached Thumbnails CLK-500 RennTech Airbox-renntech-20002.jpg   CLK-500 RennTech Airbox-renntech-20005.jpg   CLK-500 RennTech Airbox-renntech-20007.jpg   CLK-500 RennTech Airbox-renntech-20008.jpg   CLK-500 RennTech Airbox-renntech-20016.jpg
Old Feb 22, 2013 | 07:07 PM
Old Feb 23, 2013 | 02:52 AM
CLK-M113's Avatar
W207 E-400 Coupe
@ ChiCho , many thanks for the nice pictures :-) I am just modifying my standard box. Now I have a few suggestions more again. Greetings Udo
Old Feb 23, 2013 | 09:49 AM
Welcome Whatever u put as a Air Box,make sure u drop in the K&N Filters...
Old Feb 23, 2013 | 10:12 AM
CLK-M113's Avatar
W207 E-400 Coupe
hi, I have already used K&N filter. Yes, I have seen, the K&N filter are not so high as the OE filters, The suction air is able with it better stömen. I would like to raise aner still my filter lid by this stream again to improve. Greetz Udo
Old Feb 23, 2013 | 10:22 AM
Some Has installed the E55K airbox,some said they has gained hp,but u will loose the better appearance vs the stock airbox or renntech air box,so better u go with the renntech airbox,it has guaranteed gain + nice look...
Old Feb 23, 2013 | 11:17 AM
CLK-M113's Avatar
W207 E-400 Coupe
hi, thanks for your information. a friend him the 55K air box had mounted, has reported to me that none more originates power ? I would like to modify mine original air box, the lid a little higher. then an additional opening (membrane) like in the CLK350 with Sortpackage ex works obstructs. I have added 2 pictures to you, however, the air box is varnishes. greets Udo
Old Feb 23, 2013 | 04:52 PM
M-bENZ's Avatar
Corrolla
I hate to tell u this but Don't waste ur time on the modifying ur stock airbox ...you won't notice the difference that for sure .
Old Feb 23, 2013 | 05:24 PM
CLK-M113's Avatar
W207 E-400 Coupe
hi, OK, I will rise it, if I have once boredom , greetz Udo
