Finally the clk threw a code
Old Apr 10, 2013 | 11:23 AM
vsix's Avatar
JBs C63 PP( wifes car ), Mc Laren Pxx(toy), 2013 Mustang GT 5.0 ( DD ), ML 6.3 ( winter DD )...
Unfortunately only in german, hope our mbworld gurus can help to sort it out!
Code we got was:
ME.9.7 OBD
Code: 630
Einlass- Nockenwellenposition Bank 2
- Übermässige frühverstellung/ funktion fehlerhaft.
Then there were two parameters for the left and right camshaft
One Parameter said 1.0 and the other said 1.7
Code cant be cleared
Does not appear in cluster only when eading over OBD.
Thanks a bunch!
Old Apr 10, 2013 | 11:29 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This is just a generic misfire code. It should clear, unless you are having some serious engine problems and it just keeps coming back. Are you using SDS to pull codes?
Old Apr 11, 2013 | 11:51 AM
vsix's Avatar
No, I didnt had SDS...havent got a clue what kind of diagnose system it was what Im sure of is that it definately wasnt star.
I hate that the car doesnt start properly... I just hate that.. so annoying and sometimes embarrassing.
Oh boy and I thought I had a keeper this time....
Old Apr 11, 2013 | 03:54 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
So other than the error code, what are the symptoms?
Old Apr 12, 2013 | 06:24 AM
vsix's Avatar
Like I mentioned before in other threads, slight shaking ( wich you allready told me its the normal V8 behavior ) and the not-at-first-time-cranking issue.
Its like you have to sit in the car till verything got set, Seatbelt, some other noises from the fuelpump and whatever, THEN you slowly count to ten AND THEN she starts up like a dream otherwise shell crank hard....well sometimes.... Really dont know what the issue could be....
AGR?
MAF?
Crankshaft Position sensor?
Rest of the car is cool, good acceleration, great response even in C.
BTW whats the normal fuel consumption of the CLK 550?
I cant get it under 10.8 L no matter how hard I try, eventhough I would say, its pretty good considering a 5.5 L engine...
When Im back at home I will load up two vids:
First time cranking in the morning and first time cranking in the evening ( after work )...this time I dont care if I get embarrassed infront of my coworkers ...Im gonna just crank the car fast up...without waiting ...
Old Apr 12, 2013 | 04:20 PM
vsix's Avatar
Have to apologize, cant load em up...
Old Apr 12, 2013 | 10:11 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
"crank hard" as in it takes many engine revolutions before it fires, or the engine rotates slowly? If it's the former, then that could be CPS or a weak fuel pump. The latter is probably battery (or less likely the starter).
Old Apr 13, 2013 | 04:15 AM
vsix's Avatar
So you mean minor lill things need to get done....and its a keeper?
Fuelpump is in great working condition prooved by mech. He checked it.
CPS or batt.
Battery is from day one, so we might got the troublemaker :-)
Thank you Rodney!
Old Apr 13, 2013 | 12:24 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't think this is a major problem. And since your M273 engine is beyond the "balance shaft" problem range, I'd say it's a keeper.
Old Apr 13, 2013 | 01:10 PM
vsix's Avatar
Smile
Thats what I call a statement!
Thanks alot Rodney!
